  3. How to route additional cells after normal P&R
  • Subscribers 94
  • Views 1634
Sirrius
Sirrius over 18 years ago
 Hi All
My job involves taking a routed design and changing some of the cells and routing them to the cells that already exist.
I looked at some ways, and the most obvious way is to manually "Add Wire" option in Encounter. Is there any way to tell the routing tool built in (like sroute) to route the cell for me? For example, I would like to route (or connect) a cell MY_CELL1/PortA (where PortA is the port of this cell) to MY_CELL2/PortB.
Can I use sroute? If yes, then, can someone please throw a hint as to how?
Any other method? I am sure that some method should exist, which should avoid manual "Add Wire" method.
Would appreciate any help!
  • BobD
    BobD over 18 years ago
    Hi Sirrius,
    Incremental capabilities aside for a moment, which automatic routing function you should use in general depends on the nature of the signals being routed.  NanoRoute (ie, "globalDetailRoute") is typically used for routing signal and clock nets.  "sroute" is typically used for routing power/ground connections so it doesn't seem well-suited to your purpose (I'm inferring this from the PortA/PortB names you mentioned rather than VDD/VSS).
    Automatic routers in the tool rely on logical connections being in place which instruct the router as to which connections should be made.  For signal nets, these connections are determined from the input Verilog netlist primarily, which can be altered in-session with ECO commands like "addInst", "addNet", and "attachTerm".  You could verify these connections by clicking the terminals and querying their net and flight lines.
    Once these connections are logically in place, you can proceed with incrementally routing them with "globalDetailRoute".  It would probably be good to "setNanoRouteMode -routeWithEco true" to inform the tool that routing is present and the tool should incrementally refine the routing.
    Hope this helps,
    Bob
  • Sirrius
    Bob,
     Thanks for your advise. After tinkering around a bit, I was able to run ECO process. It was a tad tricky, since I was using an older verion of Encounter, which did not have "ecoDesign"
    Thanks again!
    Regards
    Sirrius
