  3. input for generating SDF
  • Subscribers 95
  • Views 21769
gops
gops over 18 years ago
What is the input file for generating SDF?In encounter there is a command writesdf.Is SDF calculated based on extracted RC.I mean SPEF file. Please somebody tell me the exact operation running in tool background when i execute writesdf.
  • BobD
    BobD over 18 years ago +1
    Upon importing a design into SoC-Encounter, along with .lib files which describing timing characteristics of cells in the design and cap tables which drive parasitic estimation, the tool can perform delay…
  • BobD
    Upon importing a design into SoC-Encounter, along with .lib files which describing timing characteristics of cells in the design and cap tables which drive parasitic estimation, the tool can perform delay calculation.  The resulting SDF file can be exported from the tool with the "write_sdf" command.
  • gops
    Hi Bob;
    Thanks for the reply.
    I have read that SDF is calculated from SPEF file.
    So while we go for write_sdf , will the tool extract parasitics and create SPEF file ?
  • BobD
    write_sdf is most typically run after the design has been timed already which is usually performed with the timeDesign super-command: "timeDesign -postRoute [-si]".  Once the design has been timed, and write_sdf is called the delay calculation in-memory will be used to output the SDF file.  I'm not sure right off whether write_sdf would trigger delay calculation if called on a design that wasn't already timed.  To be safe, I'd recommend calling timeDesign prior to write_sdf.
  • gops
    Thanks bob; i used to generate sdf file using GUI---- calculate delay.In this TAB the tool just asks for the name of the output file .Can you please tell me what the tool does internally when i generate sdf file thorough GUI.
  • Navid T
    Navid T over 17 years ago
    Navid
     Dear Bob,
     As you mentioned cap tables are needed for parasitic estimations. Also from Encounter User Guide: if cap tables are not provided, Encounter will use rough estimates for parasitics. Now, I have a 65 nm technology that has .lib and .lef files but I don't see any .ict files which are needed for Cap table generation.
     Am I supposed to make the .ict file myself? Without the cab tables, after extracting RC and calculating delay (sdf) the Encounter timing analysis built-in tool and also PrimeTime (after back-annotating sdf) show  delay values which are way beyond the expected values for this 65 nm technlogy (example: 0.5ns for an inverter). Do you think if I had cab tables, the delay would have been shorter?What you suggest me to do to get reasonable SDF file in this case?
    Thank you very much
  • Kari
    Kari over 17 years ago
     Navid,
     You *can* make an ict file yourself, but it's not much fun! The foundry should have this file for your process. Sometimes it's in a back-end kit, not the same place as your .lib and .lef file data. So check around or ask the foundry specifically for this file.
    Just for a sanity check, you can look in the .lib for the inverter and see if 0.5ns is anywhere within the timing tables. I agree that's quite high for 65nm.
    - Kari
