  3. use of SPEF file
  • Subscribers 93
  • Views 19162
use of SPEF file
gops
gops over 17 years ago
What is the purpose of extracting RC in ASIC design?Can we do simulation with the extracted RC values?Does the tool do any optimization based on RC extracted values?
  • BobD
    BobD over 17 years ago
    The primary purpose of extracting parasitics is to perform static timing analysis within the system.  SoC-Encounter has built in mechanisms for parasitic extraction, delay calculation, and static timing analysis and leverages these engines to perform optimization based on RC extracted values.  SoC-Encounter also supports import/export of SPEF for interfacing with other parasitic extraction engines and other tools.
  • gops
    Hi Bob,
    Thanks for the reply.
    Can you give the command flow to do timing analysis based on extracted data.
    Will the tool extract parasitics in the background if we do post route timing analysis
    OR
    Do we need to extract the parasitics before doing timing analysis.
  • BobD
    Yes, timeDesign will perform extraction automatically when called.
    If, by chance, you have a SPEF file from an external extraction engine that you'd like to use for timing analysis in SoC-Encounter, that SPEF file could be utilized as follows:
    spefIn design.spef
    timeDesign -reportOnly
  • gops
    thanks bob.
  • bkhimanshu
    bkhimanshu over 14 years ago
    Hi
    Could you tell how to create a spef file in encounter.
    Himanshu
  • Kari
    Kari over 13 years ago
     See the RC Extraction chapter in the User Guide.
