  3. clock tree synthesis.
  • Replies 15
  • Subscribers 96
  • Views 34336
gops
gops over 17 years ago
How should i manage CTS efficiently. I need to know what all things should be taken care in the clock tree sppecification file for an optimized clock tree. I usually create the .ctsch file from the tool itself. I just used to give the clock buffer and clock inverter foot prints for the purpose. Will this much information create the clock tree in an efficient way? if not please give me some tips to improve my clock tree. thanks gops.
  • Wizman
    Wizman over 16 years ago
    Please clarify the goal of the limitation of the buffer/inverter list? thanks
    archive over 16 years ago
    The list is required in order to specify the standard cells (inverters/buffers) that the CTS engine will use to create the clock tree. This gives you the opportunity to control which buffers/inverters will be used and therefore affect the quality of the generated clock tree by allowinfg or restricting the use of specific cells. From my experience, using inverters gives a better clock tree in terms of skew and clock insertion delay but you will need to experiment with different options to find the optimum solution.
     Hope this helps,
    Alex
  • Yemelya
    Yemelya over 15 years ago
    How can I generate a useful skew, during CTS, only for particular leafs, for example if early clock is required at clock pin of a memory?
    Thank you very much!
    Boris.
  • Kari
    Kari over 15 years ago
     Use a Macro Model for the memory clock pins. This is covered in the Clock Tree chapter in the user guide.
  • vive
    vive over 14 years ago
    Hi Carl
    when we use exclude pin we are fixing only data tran and fanout there and no skew. Why do i want to fix tran but no skew ? Pls clarify
