  3. Generating a LEF file from a layout
  • Subscribers 95
  • Views 23541
Usuomi
Usuomi over 17 years ago
 Hey all-
I need to export my layout as a LEF file.  I have used CIW>File>Export...>.  When the "Virtuoso LEF Out" menu comes up I try to specify the layout cell from which to export a LEF file.  I choose "Pattern Match" at the bottom of the screen.  Then I type the name of library/cell/view (i.e. libraryTemp/adderTemp/layout).
 I think that putting an abstract view instead of "layout" is correct.  Is this true that I need an abstract view if I want to use the LEF file in an automated layout (Magma)?
Matthew
  • Tongju
    Tongju over 17 years ago
    I usually use abstract views to create LEF file.  However, in my understanding, "Pattern Match" is used only for generating cell list file purpose and  any string pattern should be ok. At least, it was ok for me and I did get a cell list file (see your "Cell List File Name" field for the file name) with lines like "libName cellName viewName" in the file.    Tongju
  • Kari
    Kari over 17 years ago
     Hi Matthew,
    I just tried this with a layout view and I got a valid lefout.list file. However, the pattern match function is really meant for generating a lefout.list file for a lot of cells. If you are just outputing one cell, you can make your own lefout.list file with just that cell. The format is:
    libname cellname viewname
    - Kari
  • gentle
    gentle over 14 years ago
    Hi Tongju ,
    I created an inverter layout(using gpdk180 technology) from schematic(no DRC error ,no LVS error ) still on running abstract generator I am getting the error
    (ABS-216): There are insufficient metal layers defined in the current design. You must define at least two metal layers in the validLayers subsection of LEFDefaultRouteSpec  constraint group of the technology file. These layers must have the layer function "metal" in the functions section.
     (ABS-218): There are no vias specified in the technology file. Ensure that the selected constraint group has a ValidVias section or at least one via is specified in the standardViaDefs subsection of the viaDefs section in the technology file.
    I repeated the layout this time maually(not from schematic ,no drc error ,no lvs error).Still getting the same errors.
    Can you suggest me what went wrong.
    gentle
