  3. query on improving clock latency
  • Replies 7
  • Subscribers 95
  • Views 29245
abhaska
abhaska over 17 years ago
Hi all
Can anyone of you please share your views on improving clock latency in the CTS phase of the physical design flow.
-Arun
  • maven7783
    maven7783 over 17 years ago
     Hi Arun,
    A good placement of flip flops will reduce latency i,e., sink pins of  a clock are not placed far away, so that latency is reduced.
    If ffs are falling far away group them and place them relatively closer.
    thanks,
    maven.
  • Kari
    Kari over 17 years ago
     Another thing you can do is use a nondefault rule for your clocks - most folks use double-wide, double-space. This may not help as much as a really good placement, as suggested above, but it's another trick in the bag.
  • Kari
     I just came across a couple of other things you could try: look in the docs at the setCTSMode options -optLatency and -optLatencyMoveGate. These are new in 8.1 - let us know how they work for you!
  • BobD
    BobD over 17 years ago
    Great question! Reducing insertion delay is of course particularly important because it reduces the impact of timing derating on achieving timing closure.  Less insertion delay equals less effective derated clock skew, which makes it easier to achieve timign closure.
    I asked around to some of my colleagues and have some additional suggestions to consider:
    • Set a MaxDelay constraint of "0" in your clock tree spec file. This tends to task each stage of the clock tree building to focus more on insertion delay.  Note: I haven't tested this with the 8.1 setCTSMode -optLatency/-optLatencyMoveGate options Kari mentioned.
    • Constraint the clock net routing to be on upper metal layers that are less resistive using the TopPreferredLayer and BottomPreferredLayer constructs.
    • Check for the presence of FIXED, dont_touch or dont_use markings on instances and library cells (for example, clock gating cells) that exist in the clock network prior to calling CTS.
    • Try to provide at least one strong driving cell candidate that CTS can use to drive a large fanout.
    • Supply inverters to CTS rather than buffers.
    • Use the MaxCap construct to help heavily loaded and therefore slower clock buffers.
    Of course these suggestions aren't 100% effective- rather they're things that we've tried with some degree of success that we thought to share for your consideration.
    Any other ideas out there?
  • abhaska
    Hi Bob,
    Thank you for your response...
    But if the max_delay constraint was kept as zero the buffers addition will be huge in number..
    -Arun
  • BobD
    Hi Arun,
    Is that what you've observed? Or is that what you suspect would happen if you tried setting a MaxDelay of 0?
    Bob
  • dlferrao
    dlferrao over 17 years ago
     A good selection of your fast inverters & buffers in the conf file also help.
