  3. reset tree generation in Encounter
  • Subscribers 93
  • Views 15899
archive over 17 years ago
 Dear All,
 I'd like to ask if there is a methodology for routing async reset signals to flip flops. Should I perform another CTS-like step to create a buffer tree specifically for the reset signal or just leave it up to the NanoRoute?
Alex
  • Scrivner
    Scrivner over 17 years ago
     I don't normally use CTS to buffer resets. I have a max fanout setting in my constraints and I just let the optimization command use that constraint to buffer the reset net. But you can use CTS to buffer the reset if you want. This will allow you to control timing better on the reset net if it is needed.
     So far I've been using the CTS-like approach mainly in order to satisfy the demand for simultaneous exit from the reset state. So, I guess if there is no such constraint the max fanout will do just fine. Thanks! :)
