  3. Too much manual fixing.
  • Subscribers 94
  • Views 16178
potat0e
potat0e over 17 years ago
I have a design that's very low in util ~40%, 3 metal process. But after I optDesign postCTS setup and hold, the violations path are always "swinging" between the 2 different switches. When I optDesign -hold, the setup violations get worst, the option to allow fixing hold and violating setup was set to false. The numbers of violated paths didn't get less. I had to manually fix the violations by hand, adding buffers, upsizing cells. Basically doing what the tool should be doing. What could have being possible wrong? Timing constraints, placement, floorplan, etc?
  • Scrivner
    Scrivner over 17 years ago
    It sounds to me like it might be a constraints problem. It sounds like the design is overconstrained or you might have conflicting constraints. So I would start by reviewing the constaint files.
  • potat0e
    Thanks Scrivner. I am running in multimode. Do you think this would have any impacts?
  • Scrivner
    Running in multimode means that instead of checking for discrepancies within a single set of constraints, you will have to check between all sets of constraints that are used in the multimode. I would say that running multimode makes it more likely that there is a conflict in the constraints between different modes.
  • Kari
    Kari over 17 years ago
     I was going to suggest you run in MMMC, since that should prevent the problem you're describing. Make sure that all your setup views and hold views are active when you do your optDesign calls.
  • potat0e
    I was running in MMMC actually. All the respective views are active too. But it's still worth while to review the constraints files and the MMMC run file again. Thanks you folks.
