  3. Segmentation fault in SoC Encounter 4.1 with Nanoroute
  • Subscribers 93
  • Views 18317
archive over 20 years ago
I want to route my design in SoC Encounter and I use the follow script for Nanoroute:
setNanoRouteMode -quiet routeFixPrewire true
setNanoRouteMode -quiet route_selected_net_only false
setNanoRouteMode -quiet routeWithTimingDriven false
setNanoRouteMode -quiet routeTdrEffort 1
setNanoRouteMode -quiet drouteFixAntenna true
setNanoRouteMode -quiet routeWithSiDriven true
setNanoRouteMode -quiet routeSiLengthLimit 200
setNanoRouteMode -quiet routeSiEffort normal
globalDetailRoute
This work without problem.
But as I want to avoid routing on the first layer, I also add the follow option:
setNanoRouteMode -quiet routeBottomRoutingLayer 2
But with this option the program report an segmentation fault.
What's I'm doing wrong?
Christian
Originally posted in cdnusers.org by lets
    Dear Christian,
    Its not a bad idea to block M2 ( metal 2 layer ) on your design ,
    But one thing is it really possible to block whole M2 in the design think practically . NO
    how ever you can do the same by blocking M1 in your design , as STD cell pins can reach M2.
    Suggestion .
    1. Add M2 routing blockage over a region to restrict so .
    2. check placement ( and see unplaced count is = 0 )
    If you are blocking M2 for only clock nets then its OK then use
    setAttribute -net @CLOCK -bottom_preferred_routing_layer 2 -top_preferred_routing_layer 4
    setNanoRouteMode routeTopRoutingLayer 4
    setNanoRouteMode routeBottomRoutingLayer 2
    Originally posted in cdnusers.org by mohanch007
    Thank you for your answer, but I think there is a misunderstood.
    What I want is to route on layer 2-7 compared to the "normal" 1-7, so it is the first layer that I don't want to route on.
    The real problem is that the command routeBottomRoutingLayer give me a segmentation fault.
    Is there an incompatibility of this command with others Nanoroute options?
    Thanks again
    Christian
    Hi Christian,
    As Mohanch mentioned, it is impossible to route layer 1-7 if you have pin on metal1 (note: layer1 is metal1 and layer 7 is metal7).
    Most std cell pins are on metal1.
    Eng Han
    Originally posted in cdnusers.org by EngHan
    Hi Christian,
    If you ready want to route 2-7, then you must also tell the software which net you want to route. You have to make sure those net does not need to connect to metal1 pin.
    Eng Han
    HI ,
     Since 3 years we are using Soce and i have not fased such problems ,
    Its duffecult to justify the right reason for such issues spacific to your design .
    check how are the WARNINGS and ERROR msg.  at the time of loading and running nano route.
    In practical I have even limited using some layers on all subversion of 4.1 . -NO PROBLEM .
    If possible can you please let me know on which technology and your encounter.log & cmd file ... not all only the Nano route attrebuts and reported log.
    advice  before sending more details
    1. before globaldetail  route just check  Global Route .
    and check each layer conjesion map .
    during Global route check :
    #Start data preparation...
    # #Using automatically generated gcell grid.
    # Layer Direction #Track Blocked #Gcell Blocked
    # Metal 1 V 10249 37.73% 466489 26.39%
    # Metal 2 H 10250 15.61% 466489 28.03%
    # Metal 3 V 10249 12.81% 466489 30.53%
    # Metal 4 H 10250 30.34% 466489 26.46%
    # Metal 5 V 8200 29.28% 466489 25.71%
    # Metal 6 H 3416 27.51% 466489 26.03%
    # Metal 7 V 1282 8.27% 466489 18.09%
    # Total 53896 27.36% 3265423 24.46%
    #cpu time = 00:00:09, elapsed time = 00:00:19, memory = 200.00 (Mb)
    #start global routing iteration 1...
    #cpu time = 00:00:03, elapsed time = 00:00:07, memory = 202.00 (Mb)
    #start global routing iteration 2...
    #start global routing iteration 6...
    #cpu time = 00:00:14, elapsed time = 00:00:25, memory = 202.00 (Mb)
    # Layer #OverCon %OverCon
    # Metal 1 2 0.00%
    # Metal 2 0 0.00%
    # Metal 3 2 0.00%
    # Metal 4 0 0.00%
    # Metal 5 0 0.00%
    # Metal 6 0 0.00%
    # Metal 7 0 0.00%
    # Total 4 0.00%
    #Complete Global Routing.
    #Total wire length = 580805 um.
    #Total half perimeter of net bounding box = 227492 um.
    #Total wire length on LAYER M1 = 88617 um.
    #Total wire length on LAYER M2 = 294704 um.
    #Total wire length on LAYER M3 = 221670 um.
    #Total wire length on LAYER M4 = 5812 um.
    #Total wire length on LAYER M5 = 5344 um.
    2. use Routing Control ( area Route ) and try .
    [command ]
    globalRoute
    detailRoute
    globalDetailRoute
    ################## # Routing Control ##############
    #### [option]
    setNanoRouteMode -routeSelectedNetOnly false (bool)
    setNanoRouteMode -routeBottomRoutingLayer default (integer/dynamic)
     setNanoRouteMode -routeTopRoutingLayer default (integer/dynamic)
    setNanoRouteMode -routeWithEco false (bool)
    [command]
     globalDetailRoute
    detailRoute
    Best Regards,
    Mohan
    HI ,
     Since 3 years we are using Soce and i have not faced such problems ,
    Its difficult to justify the right reason for such issues specific to your design .
    check how are the WARNINGS and ERROR msg.  at the time of loading and running nanoroute.
    If possible can you please let me know on which technology and your encounter.log & cmd file ... not all only the Nanoroute attributes and reported log.
    and check each layer congestion map .
    # Metal 1 2 0.00%
    # Metal 2 0 0.00%
    # Metal 3 2 0.00%
    # Metal 4 0 0.00%
    # Metal 5 0 0.00%
    # Metal 6 0 0.00%
    # Metal 7 0 0.00%
    # Total 4 0.00%
    [command ]
    globalRoute
    detailRoute
    globalDetailRoute
    #### [option]
    [command]
     globalDetailRoute
    detailRoute
    Best Regards,
    Mohan
