  3. What are tiehi and tielo cells?
  • Replies 7
  • Subscribers 95
  • Views 26504
NAADHAN
NAADHAN over 17 years ago
Hi all,
Please can any one explain me what are 'tiehi' and 'tielo' cells ? and how are they used in designing ?
Thanks & Regards,
NAADHAN
  • aplumb
    aplumb over 17 years ago
    You typically use them to tie unused inputs to logic-high or logic-low. Strange Things happen if you don't. Andrew.
  • Kari
    Kari over 17 years ago
    Not all designs use tie cells. I have found this to be a customer preference, although apparently there are benefits to using them, such as some ESD protection.
    In a design without tie cells, unused inputs are tied to logic-high or logic-low, and these connections are made by routing the input pin right to the pwr/gnd grid.
    In a design with tie cells, unused inputs in the original netlist are tied to logic-high or logic-low, and somewhere during the physical design process, tie cells are inserted. The unused inputs are then connected to a tiehi or tielo cell.
    Adding tie cells in Encounter is very easy:
     addTieHiLo -cell "TIEHI TIELO"
    There are other options to the addTieHiLo command, as well as the setTiHiLoMode command, so please check the docs for your specific needs.
  • NAADHAN
    Thank you 'aplumb'.
    Thank you so much 'Kari' now am clear about this :-)
  • DaBorg
    DaBorg over 17 years ago
    Well, tie cells can have even more benefits. But ESD is the main reason. Having the power/ground net connected to a fragile min size gate CMOS transistor is not ideal for high ESD requirements.
    For example, you can design a tie cell with metal mask programmable 0/1, which can be used for a small ROM in your design. Very practical. I'd recommend adding the tie cells during synthesis. But that's my personal preference.
    In RTL Compiler:
      insert_tiehilo_cells [-hilo <libcell>] [-hi <libcell>] [-lo <libcell>] [-all] [-maxfanout <integer>] [-verbose] [-skip_unused_hier_pins]  [<design|subdesign>]
    Make sure you enable -skip_unused_hier_pins as you otherwise may get unnecessary floating tie cells. Use the -maxfanout to define how many gates the tie cell can drive. This is good for reducing the number of tie cells and thus area.
  • NAADHAN
    Thanks for the suggestion DaBorg :-)..."metal mask programmable 0/1"----> pls can you elaborate on this for me?... am not clear about this part....
    Thanks and Regards,
    NAADHAN
  • DaBorg
    Let's say you need to do an ECO with only one metal mask in order to change a 0 to a 1 on the input of one of your combinatorial gates, but you only have one tie down cell available. If this tie down cell was designed such that you can easily change its function from 0 to 1 by using only one metal layer, then that would be a cost effective change for a localized ECO.
  • NAADHAN
    Thanks DaBorg.... now am understood the purpose of metal mask programmable tieCell..
    NAADHAN
