  3. How to update input delay with clock latency during APR...
  • Subscribers 95
  • Views 15819
How to update input delay with clock latency during APR in SOC encounter
jsjsjsjs
jsjsjsjs over 17 years ago
I am trying to design a bank of 64 multipliers that receive operands from a pipeline register. I have set the input delays at 200pS. Encounter reports a clock latency of 600pS. However since it does not know that the operands to the multipliers will eventually come from a FF. Hence it is reporting hold violations and trying ti fix these.
One way to get around it is to use an input delay of 800pS.....Is there any other way to tell encounter to update the delays by adding the clock latency...
Thanks.
Sudhir
  • lisiang
    lisiang over 17 years ago
    get your Cadence AE to send you a tcl file "rda_updateSDC.tcl" and it should update the set_input_delay & set_outout_delay for teh added clock latency.
    li siang
  • jsjsjsjs
     Thanks for your response...Can you explain it a little more ? Like what exactly the command is and when to use it..... A sample script will help me a lot
    Waiting for your reply
