  3. Why there is a difference in Optimisation when we change...
  • Subscribers 96
  • Views 16421
Why there is a difference in Optimisation when we change clock period directly instead of changing the uncertainty?
NAADHAN
NAADHAN over 17 years ago
Hi ,
 In our project we have a single clock....Here we run mutiple placement runs by targetting higher frequencies. This can be done in two ways          1.By changing the uncertainty each time keeping the clock period constant.
                  2.By Changing the clock period each time keeping the uncertainty constant.
Here in the both the approach when we target for the same frequency(Eg: 1)Period:2ns & uncertainty:100ps 2)Period:1.9ns& uncertainty:0ps) ....we get entirely different results.....
 So can anyOne Pls explain me how does the tool undertands the  change in uncertainity and change in time period..????
Thanks & Regards,
Naadhan
  • geleshan
    geleshan over 17 years ago
    The 1)Period:2ns & uncertainty:100ps 2)Period:1.9ns& uncertainty:0ps are quite different during "hold" timing check.
    When calculate "hold" timing:
    For case (1).  the capture clock pin "see" the period 2.1ns (2.0 original period plus 0.1 uncertainty)
    For case (2). the capture clock pin "see" the period 1.9ns. (1.9 original period plus 0.0 uncertainty).
    So, your case (1) result may have much more buffer added to avoid hold violations.
     Gele
  • NAADHAN
    Thanks a lot Gele....But FYI we dont to any hold optimisation in our Design...We do only setup Optimisation ....So am still not sure why this difference is comming...thats why i doubt how the tool interprets the time period and uncertainty while optimising for timing(Setup)?!
    NAADHAN
  • frankz
    frankz over 17 years ago
     Based on my understanding of Cadence placement, I don't think tool generates different placement quality because of your different timing constraint setting. You should use this 2 sdc file based on 1 same placement database to report timing and it won't show you any different slack. Even if you provide the same timing constraint and run multi placement, Cadence placement will give you supurise.
    It's random for no reason.
     You can try 10 runs with exact same floorplan same timing constraint (everything same) and do placement.
    You will see the interesting thing. :)
  • NAADHAN
    Hi frankz....thats correct we have also observed that we cannot recreate the same placement and placement timing with similar constraints.... its both an advantage and a disadavantage too....;D
    Thanks and Regards,
    NAADHAN
