  3. RC doesn't use up all available memory and crashes
  • Subscribers 94
  • Views 1495
naderi
naderi over 17 years ago
 Hi All,
I am trying to synthesis a larg design in a machine with 32GB of RAM. But RC  doesn't use the available memory and crashes after 4GB usage.
Following is the error messag:
No more memory.  Current memory consumption: 4162452K.Abnormal exit.
No more memory.  Current memory consumption: 4162460K.
Encounter_soc also reports such an error.
Is there any switch in RC to push this memory usage limit?
Ali
  • grasshopper
    grasshopper over 17 years ago
     Hi Nader,
     did you invoke RC with the -64 switch ? If the system is 64-bit default behavior is not to invoke the 64-bit executable. This is so as not to penalize runtime / memory on designs that do not need to use the 64-bit capabilities. Look in the header at the beginning of your log and confirm whether you invoked the 64-bit or 32-bit executable
    good luck,
    gh-
  • naderi
     Hello grasshopper
    Excellent! I couldn't imagine it would have such an effect.
     Thank you very much indeed.
     Best,
    Ali
