  3. Gate level netlist from Verilog XL
  • Subscribers 94
  • Views 16879
tswong
tswong over 17 years ago
I am trying to generate a verilog gate netlist from a cadence schematics with standard cells by Verlilog XL, but it always return with an errors on standard cell. Does anyone see this type of error before?
ERROR: Netlister: cannot find master of instance I0 in cell INVX1.
ERROR: Netlister: cannot find master of instance I0 in cell AND3X1.
ERROR: Netlister: cannot find master of instance I0 in cell AND2X1.
  • Tongju
    Tongju over 17 years ago
    From the error message, the netlister is not guided to stop at the standard cell level (INVX1, AND3X1, ...). Instead, it decended into the stdcells and couldn't find a valid view for the instances inside those stdcells.  Have you provided a stop view name to the netlister for those stdcells?
  • tswong
    Tongju,
    Thanks for your reply! I wonder which view I should provide to the netlister. I was told by someone else that a "verilog" view must be created for netlisting. Do you have any idea on generate a verilog view on std cell library....
  • Tongju
    The "verilog" view will be good enough for the netlister. One way to create it is to choose "Verilog_editor" as the Tool Name in the Create Cell View form (file->new->View in library manager). This kind of views will make SOC encounter and verilog simulators happy.
     For the purpose to have a stop view for the netlister to create netlist for SOC encounter, a simpler version may work fine. For example, you could just simply open the symbol view of a cell and save it as a new view with new name (for example, "soc") and then, put "soc" into your stop view list when you do the netlisting. You should be able to create a netlist without any problem!
     Tongju
  • tswong
    Tongju, thanks for your help and I can generate the netlist right now!
