  3. how to fix fewer short violation?
  • Subscribers 94
  • Views 17711
magicflute
magicflute over 17 years ago
in my design. after nanorouting, i find here fewer short violations, i use following command to fix:
1)editDeleteViolations
2)globalDetailRoute
but still 5~7 short violations can not be fixed. i view in the layout,i find there seems to be spaces to route, why not use the resource?   can anyone tell me other way to do?
  • Kari
    Kari over 17 years ago
     It's hard to say without seeing the design. Did you try to fix one or two of the shorts by hand? It may not be as easy as it first looks. You could try a nanoRoute run where you route only selected nets, and select the shorting nets, or try routing those nets first if you are doing another route pass from scratch... just throwing out some ideas.
