  3. xtalk simulation failed
  • Subscribers 95
  • Views 15260
Upender
Upender over 17 years ago
Hi ,
When doing cross talk analysis on a post -routed board,  cross talk summary window always gives the results as
 Victim XNet                       Victim Drvr                  HSOddXtalk  HSEvenXtalk  LSOddXtalk  LSEvenXtalk  Group
xxxxx                               yyyyy                                        NA          NA           NA          NA           Group all_tw
 for all nets.
Geometic window 16mils, trace width 4 mils.  spacing between aggressor and victim is 8 mils and they run 50mm in parallel..
The results always show NA .
does anyone know  to set any other parameters for xtalk. tool used Cadence 16.2 PCB SI XL.
Thanx,
Upen
  • Chalford
    Chalford over 17 years ago
    Hi Upen,
    What are your stimulus and preference settings for your xtalk simulation?Some combinations will prevent the report from displaying the results, and instead cause "NA" to be displayed. For instance, if the stimulus is "Pulse" but "cycles" is set to "3" then this will cause "NA" in the voltage columns.
    After you have run your sims, do you have a signoise.run/casen/waveforms directory? Does it have a *.sim file for each simulation?
    Best regards,
    Chris
  • Upender
    Hi Chris,
    Wave form directory is not created when the simulation fails.
    I have a 20 layer symmetric stack –up, signals selected from some layer produce results,  few other layers does not give for the same case settings.
    Cross-section seems to be fine
    Field solver used is EMS2D
    Upen
