  3. Run foundation scripts & run database access commands
  • Subscribers 93
  • Views 1410
KVBABU
KVBABU over 17 years ago
 Hi friends,
While browsing some  details regarding various trainings on cadence tools , i found some learning objectives like  :
 1) Run foundation scripts
  2) run database access commands
What exactly these mean. and how technically helpfull they are , Could you explain me with an example. So that i can participate for training classes with atleast a basic and minimum  knowledge.
K.VISWANADH BABU
  • Kari
    Kari over 17 years ago
     I assume you're talking about Encounter?
     If so, the documentation has several things that should get you started.
    http://sourcelink.cadence.com/docs/files/Release_Info/Docs/landing/soc81/library.html
    Scroll down to "E".
    You'll see several documents regarding the Foundation Flows, and a Database Access Command Reference, but for db access I recommend starting with dbGet in the chapter of the Text Command Reference called  "Basic Database Access TCL Commands".
    Hope that helps,
    - Kari
