  3. Flattened sdf file from hierarchical project
  • Subscribers 94
  • Views 16278
Xtof
Xtof over 17 years ago
I need to export both a hierarchical and a flattened verilog netlist  from Encounter (8.1) with their corresponding sdf files. For the netlist, I use 'saveNetlist filename.v' and 'saveNetlist -flat filename_flat.v' commands but for the sdf, 'write_sdf' doesn't support the -flat parameter.
 How do I get the sdf for the flattened netlist?
Thank you for the help!
 Xtof
  • Kari
    Kari over 17 years ago
     Did you try starting a new Encounter session, importing the design with your flat verilog, and then doing write_sdf? Just an idea...
  • Xtof
     Hi Kari,
    Thanks for your response.
    I can certainly do that, but I would end up with a different layout, etc. I need the hierarchical and flattened netlists to be identical. Hence the problem...
    -Christophe
  • Kari
    I'm not suggesting you start from scratch with the flat netlist. With your design up, you can write out either a flat or hier verilog. Also write out a DEF file. DEF is by nature "flat", so it should match either netlist. Your layout info should be the same. In a new session, read in the flat verillog and the DEF. Let us know if it works for you.
