  3. Question about verify errros of Abstract Generator
  • Subscribers 94
  • Views 15643
Zhou Zhao
Zhou Zhao over 17 years ago
I plan to build up a std lib using AMIS 0.5um tech. The schematic and layout of std cells are designed in IC 5.1.41. I use the Abstract Generator to generate the LEF of std lib. All stages including pin, extract, and abstract are passed without errors. However, there are three errors in verify stage shown below.
ERROR (ABS-1069): Cell pllclk: Encounter: Could not open shared library liboax22.so : /cad/cds/SOC62/tools.lnx86/lib/liboax22.so: undefined symbol: _ZN12OpenAccess_419oaVersionedObserverINS_12oaLibDefListELj0EE13onPreOpenLibsEPS1_.
ERROR (ABS-1069): Cell pllclk: Encounter: OA features will be disabled in this session..
ERROR (ABS-1056): Cell pllclk: unable to verify abstract view in target place-and-route system. Please refer to the place-and-route system's log file in .abstract/verify for more information.
I use SOC 6.2 Encounter for auto PR. I wonder how to troubleshoot above errors. In addition, the generated LEF file is empty.
  • Zhou Zhao
    I figured out the errors coming from the incompatibility between Abstract Generator and SOC 6.2 Encounter. Therefore, I installed the SOC 7.1. When I went through the tutorial project pllclk in Abstract Generator User Guide, there are no errors in verify stage. However, the Abstract Generator runs forever in the verify stage for my own AMIS std lib test design. It seems the abstract file can not be processed, but there is no any errors in the Abstract stage. Thank you for any comments. The log file is
    LOG (ABS-1420): Starting @(#)$CDS: ui version 5.1.0 01/08/2009 01:49 (cicln04) $, sub-version 5.10.41.500.6.130, on Linux 2.4.9-e.57enterprise
    *WARNING* '/home/zhaozhou/AMIS/cds.lib', Line 10: Skipping: 'libs/smi_io_test2'
    INFO (ABS-100): Library stdcell opening /home/zhaozhou/AMIS/stdcell
    *WARNING* dbOpenCellViewByType: Failed to open cellView (via symbolic) from lib (amis500cxakxx) in 'r' mode because cellview does not exist.
    *WARNING* invalid cell view -- 0(unknown)
    *WARNING* dbOpenCellViewByType: Failed to open cellView (viaN layout) from lib (amis500cxakxx) in 'r' mode because cellview does not exist.
    *WARNING* dbOpenCellViewByType: Failed to open cellView (viaS layout) from lib (amis500cxakxx) in 'r' mode because cellview does not exist.
    *WARNING* dbOpenCellViewByType: Failed to open cellView (viaE layout) from lib (amis500cxakxx) in 'r' mode because cellview does not exist.
    *WARNING* dbOpenCellViewByType: Failed to open cellView (viaW layout) from lib (amis500cxakxx) in 'r' mode because cellview does not exist.
    *WARNING* dbOpenCellViewByType: Failed to open cellView (via2 symbolic) from lib (amis500cxakxx) in 'r' mode because cellview does not exist.
    *WARNING* dbOpenCellViewByType: Failed to open cellView (via2N layout) from lib (amis500cxakxx) in 'r' mode because cellview does not exist.
    *WARNING* dbOpenCellViewByType: Failed to open cellView (via2S layout) from lib (amis500cxakxx) in 'r' mode because cellview does not exist.
    *WARNING* dbOpenCellViewByType: Failed to open cellView (via2E layout) from lib (amis500cxakxx) in 'r' mode because cellview does not exist.
    *WARNING* dbOpenCellViewByType: Failed to open cellView (via2W layout) from lib (amis500cxakxx) in 'r' mode because cellview does not exist.
    LOG (ABS-212): Verifying Technology Data
    WARNING (ABS-252): Cannot create layer-purpose pair (DIF, boundary) in the technology file. Check that you have permission to write to the technology file.
    INFO (ABS-254): Cannot save technology file. Check that you have permission to write to the technology file.
    INFO (ABS-232): Layer summary: 3 metal layer(s), 2 via layer(s), 1 poly layer(s), and 1 diff layer(s) found
    INFO (ABS-234): Via summary: 13 default via(s) and 0 non-default via(s) found
    INFO (ABS-104): Library stdcell no options loaded
    INFO (ABS-103): Library stdcell loading options from /home/zhaozhou/AMIS/stdcell/.abstract.options
    INFO (ABS-105): Library stdcell loading messages from /home/zhaozhou/AMIS/stdcell/.abstract.messages
    INFO (ABS-101): Library stdcell loading 5 cells
    INFO (ABS-102): Library stdcell loaded 5 cells
    INFO (ABS-108): Library stdcell opened
    INFO (ABS-110): Library stdcell saving existing options file to /home/zhaozhou/AMIS/stdcell/.abstract.options.prev
    INFO (ABS-112): Library stdcell saving options to file /home/zhaozhou/AMIS/stdcell/.abstract.options
    LOG (ABS-1300): Cell inverter: step Pins started
    INFO (ABS-514): Cell inverter: prBoundary successfully created.
    INFO (ABS-501): Cell inverter: 4 existing terminals, no pins will be added
    LOG (ABS-1301): Cell inverter: step Pins finished
    Loading SKILL PCell files from:
    /cad/cds/AMIS/ami500hakx/lib/amis500cx/physical/dfii/amis500cxatxx/Rev2.8/epm/layout/../../skill
    loading: Amis500cxatxx_AmisRpcBuildMetal1Res.ile
    loading: Amis500cxatxx_AmisRpcBuildNDiffRes.ile
    loading: Amis500cxatxx_AmisRpcBuildNWellRndCorner.ile
    loading: Amis500cxatxx_AmisRpcBuildP1P2GateCap.ile
    loading: Amis500cxatxx_AmisRpcBuildGatePath.ile
    loading: Amis500cxatxx_AmisRpcBuildExtDrainNmos.ile
    loading: Amis500cxatxx_AmisRpcBuildMosPPCap.ile
    loading: Amis500cxatxx_AmisRpcMetalResSqrCorner.ile
    loading: Amis500cxatxx_AmisRpcBuildContacts.ile
    loading: Amis500cxatxx_AmisRpcGetInterdigPoints.ile
    loading: Amis500cxatxx_AmisRpcBuildLowVoltageLayer.ile
    loading: Amis500cxatxx_AmisRpcMosTran.ile
    loading: Amis500cxatxx_AmisRpcOrderMOSObjects.ile
    loading: Amis500cxatxx_AmisRpcBuildPmosLayers.ile
    loading: Amis500cxatxx_AmisRpcBuildHiPolySqrCorner.ile
    loading: Amis500cxatxx_AmisRpcCapCB.ile
    loading: Amis500cxatxx_AmisRpcBuildMetalRes.ile
    loading: Amis500cxatxx_AmisRpcBuildPoly2RndCorner.ile
    loading: Amis500cxatxx_AmisRpcBuildNDiffRndCorner.ile
    loading: Amis500cxatxx_AmisRpcAddGuardringToRes.ile
    loading: Amis500cxatxx_AmisRpcBuildNDiffSegmented.ile
    loading: Amis500cxatxx_AmisRpcBuildPoly1Segmented.ile
    loading: Amis500cxatxx_AmisRpcExtMosTran.ile
    loading: Amis500cxatxx_AmisRpcBuildNWellSegmented.ile
    loading: Amis500cxatxx_AmisRpcBuildContactPath.ile
    loading: Amis500cxatxx_AmisRpcBuildNWellSqrCorner.ile
    loading: Amis500cxatxx_AmisRpcBuildNetMarker.ile
    loading: Amis500cxatxx_AmisRpcBuildMosPPCapArray.ile
    loading: Amis500cxatxx_AmisRpcBuildNWellRes.ile
    loading: Amis500cxatxx_AmisRpcBuildPoly1RndCorner.ile
    loading: Amis500cxatxx_AmisRpcBuildHiPolyRndCorner.ile
    loading: Amis500cxatxx_AmisRpcBuildExtSource.ile
    loading: Amis500cxatxx_AmisRpcAddM2StrapToGBar.ile
    loading: Amis500cxatxx_AmisRpcBuildExtPolyConn.ile
    loading: Amis500cxatxx_AmisRpcBuildHiPolyRes.ile
    loading: Amis500cxatxx_AmisRpcAddChopHole.ile
    loading: Amis500cxatxx_AmisRpcBuildExtDrainPmos.ile
    loading: Amis500cxatxx_AmisRpcBuildMosGBar.ile
    loading: Amis500cxatxx_AmisRpcBuildGateCap.ile
    loading: Amis500cxatxx_AmisRpcBuildPoly2Segmented.ile
    loading: Amis500cxatxx_AmisRpcBuildPoly2SqrCorner.ile
    loading: Amis500cxatxx_AmisRpcBuildExtGuardbar.ile
    loading: Amis500cxatxx_AmisRpcFixModelName.ile
    loading: Amis500cxatxx_AmisRpcCapStretch.ile
    loading: Amis500cxatxx_AmisRpcLoadAssocTable.ile
    loading: Amis500cxatxx_AmisRpcBuildPoly1Res.ile
    loading: Amis500cxatxx_AmisRpcBuildProbe.ile
    loading: Amis500cxatxx_AmisRpcGeomFunc.ile
    loading: Amis500cxatxx_AmisRpcBuildPoly1SqrCorner.ile
    loading: Amis500cxatxx_AmisRpcGetResType.ile
    loading: Amis500cxatxx_AmisRpcBuildMetal2Res.ile
    loading: Amis500cxatxx_AmisRpcBuildHiPolySegmented.ile
    loading: Amis500cxatxx_AmisRpcMakePlateConns.ile
    loading: Amis500cxatxx_AmisRpcBuildSrcDrn.ile
    loading: Amis500cxatxx_AmisRpcBuildPoly2Res.ile
    loading: Amis500cxatxx_AmisRpcBuildNDiffSqrCorner.ile
    loading: Amis500cxatxx_AmisRpcBuildExtGate.ile
    loading: Amis500cxatxx_AmisRpcPlaceSegConns.ile
    loading: Amis500cxatxx_AmisRpcPlaceStraps.ile
    loading: Amis500cxatxx_AmisRpcBuildPDiffRes.ile
    loading: Amis500cxatxx_AmisRpcCalculatePathPts.ile
    loading: Amis500cxatxx_AmisRpcBuildMetal3Res.ile
    Loading SKILL files completed.
    LOG (ABS-1300): Cell inverter: step Extract started
    INFO (ABS-602): Cell inverter: extracting 4 nets
    INFO (ABS-605): Cell inverter: using preset pins on net Z, 1 of 4
    INFO (ABS-605): Cell inverter: using preset pins on net A, 2 of 4
    INFO (ABS-604): Cell inverter: extracting net vdd!, 3 of 4
    INFO (ABS-604): Cell inverter: extracting net vss!, 4 of 4
    LOG (ABS-1301): Cell inverter: step Extract finished
    LOG (ABS-1300): Cell inverter: step Abstract started
    INFO (ABS-904): Cell inverter: overlap layer created
    INFO (ABS-1425): Generating cover blockages for layer M1
    INFO (ABS-1425): Generating cover blockages for layer M2
    INFO (ABS-1425): Generating cover blockages for layer M3
    LOG (ABS-1301): Cell inverter: step Abstract finished
    LOG (ABS-1300): Cell inverter: step Verify started
    *WARNING* Could not locate rgb.txt file in /usr/lib/X11
    *WARNING* This file is required for color operations with the non-graphical
    *WARNING* X server and many WARNING messages may follow this one!
    Xlib: extension "Generic Event Extension" missing on display "backup:500.1".
    COPYRIGHT © 1992-2008 CADENCE DESIGN SYSTEMS INC. ALL RIGHTS RESERVED.
    © 1992-2008 UNIX SYSTEMS Laboratories INC.,
    Reproduced with permission.
    This Cadence Design Systems program and online documentation are
    proprietary/confidential information and may be disclosed/used only
    as authorized in a license agreement controlling such use and disclosure.
    RESTRICTED RIGHTS NOTICE (SHORT FORM)
    Use/reproduction/disclosure is subject to restriction
    set forth at FAR 1252.227-19 or its equivalent.
    *WARNING* X-Colormap overflow.
    *WARNING* Colors edfiCo41, edfiCo65, edfiCo73, edfiCo74, edfiCo83, edfiCo85, edfiCo92, edfiCo96, edfiCo106, edfiCo109, edfiCo124, edfiCo136, edfiCo139, silverB, pinkB, orangeB, purpleB, greenB, brownB, blueB, goldB, winColor5B, and joy1 are not defined.
    Please exit some of applications to free color cells from X-Colormap
    or increase layer pool size by "setenv CDS_LAYER_POOL_SIZE n".
    *Error* ilGetInt: arg must be fixnum - nil
    Loading FLutil.cxt
    LEFOUT: beginning output...
    Product : Virtuoso(R) LEF Out
    Program : lefdef version 5.1.0 Thu Jan 8 01:52:44 PST 2009 (cicln04)
    SubVersion: sub-version 5.10.41.500.6.130
    Started at: 08-Sep-2009 15:53:59
    User Name : zhaozhou
    Host Name : backup
    Directory : /home/zhaozhou/AMIS
    CADENCE Design Systems, Inc.
    LEFOUT: Generating list of valid layers...
    Layers are successfully generated
