  3. Tracks and grid points
  • Subscribers 94
  • Views 15471
maven7783
maven7783 over 17 years ago
HI,
Does the tracks in the encounter and the grid points in virtuoso have a relation between them for a same technology?
I think tracks in encounter will be in multiples of grid points. Correct me if i am wrong.
Could someone elaborate on the grid types we use during the flow.
Thanks in advance.
  • Kari
    Kari over 17 years ago
    I'm not sure which specific gridpoints you're talking about in Virtuoso, because I know you can set the cursor to snap to whatever resolution you want, but in general, the "grid" in Virtuoso would be the manufacturing grid. That's the smallest resolution of your process. Typical values could be 0.01 um, 0.005 um, etc.
    The tracks in Encounter generally refer to routing tracks. These are the routing pitches for the various metal layers. But Encounter understands the manufacturing grid too - it's a setting in the tech LEF file. It's important for Encounter to know what the manufacturing grid is, because all objects must align to the manufacturing grid. Otherwise, you'll fail DRC.  Routing tracks, metal widths, std cell sizes, SITE sizes, ROW locations, etc. must all align or be multiples of the manufacturing grid, as you already guessed.
    Hope that helps,
    - Kari
  • maven7783
    I was refering to manufacturing grid, Kari.
    i got the answer.
    thank you for your reply.
