  3. Programmatic global net connect access
  • Subscribers 94
  • Views 15724
jgentry
jgentry over 17 years ago
I was wondering if there is a programmatic way to get access to the globalNetConnect information.  For my power pins, I want to access what global net they are connected to.  I'm currently implementing it as a look-up table using array indices but it is breaking down when my users specify wildcard patterns for the pin name (i.e. globalNetConnect -pin PLL*VDD -net PLL_V10_25_VDD).  It looks like the GUI knows instantly which global net a pin is connected to by looking at the attribute pop-up.
JG
  • jgentry
     Hmm, I guess I'm going to answer my own question (not sure how I missed this before):
    set termPtr [dbGetPGTermByName $instPtr $pinName]
    set netPtr [dbPGTermNet $termPtr]
    set netName [dbNetName $netPtr]
    JG
  • BobD
    BobD over 17 years ago
    No problem answering your own question, JG.  Thanks for contributing the information to the forum!
    There's also support for pgterms within dbGet (as opposed to the FE-TCL-style in your 2nd post).  It's not 100% straightforward however, so here's an example of what that would look like in case you (or someone else who comes across this post) might like/need to pursue that path at some point:
    encounter 30> set instPtr [dbGetInstByName i0]
    0x2a9f706710
    encounter 31> dbGet $instPtr.pgCellTerms.name
    VDD VSS
    encounter 32> dbGet $instPtr.pgTermNets.name
    VDD 0x0
    The thing that's not straightforward about it is that there's not a pgTerm object directly off the inst.  The name of the pgTerm is accessed via the pgCellTerm and the name of the net is accessed via the pgTermNet.
