  3. How to handle assign statements
  • Replies 9
  • Subscribers 92
  • Views 19310
archive over 18 years ago
In our design, we have few signals which need to be tied to 1'b0, 1'b1, as shown below.
    assign z[16] = 1'b0 ;
    assign port_comp[0] = 1'b1;
During PD, I want to tie these nets to VDD and GND nets. Can somebody help on how to do this?
Thanks in Advance,
Krishna
Originally posted in cdnusers.org by gukumar
    Try adding tie cells before writing verilog.
    If you work with RTL - Compiler it looks like:
    remove_assigns
    insert_tiehilo_cells
    Originally posted in cdnusers.org by Stalker
    Hi Stalker,
    The ASIC vendors that we are dealing with do not have TieHi/TieLo cells in their library. So we need to connect these nets directly to vdd/gnd. Is there a way to do this, either in SoCE or RTL-C.
    Thanks;
    Krishna
    I never connected cells directly to the grid.
    As far as I know LVS tools recognize 1'b0/1'b1 as vss/vdd
    so can we leave the nets floating. i thought there is a way to connect all 1'b0 to gnd and 1'b1 to vdd.
    Hi Krishna,
    Make sure you have the following in your .conf file before loading the design: (NOTE this is an example; make sure to use your specific pwr/gnd net names and std cell pin names. These are usually VDD/VSS, but can be different.)
    set rda_Input(ui_pg_connections) [list \
    {PIN:VDD:} \
    {PIN:VSS:} \
    {TIEHI::} \
    {TIELO::} \
    set rda_Input(PIN:VDD:) {VDD}
    set rda_Input(PIN:VSS:) {VSS}
    set rda_Input(TIEHI::) {VDD}
    set rda_Input(TIELO::) {VSS}
    This should setup tiehi/lo nets and nanoroute should connect them.
    Hope that helps,
    - Kari
    Originally posted in cdnusers.org by Kari
    Thanks Kari. It worked.
    You're welcome, Krishna. I'm glad that worked for you.
    - Kari
  • PramodSabnis
    PramodSabnis over 17 years ago
    Hi Kari/ Krishna,
    In this, I understand that VDD and VSS are the power and ground nets. But, what are "TIEHI::" and "TIELO::" keyword?
    Sorry for this stupid question. But I am facing the same problem.
    Pramod
  • Kari
    Kari over 17 years ago
     Hi Pramod,
    There are no stupid questions! :-)
    The TIEHI and TIELO keywords are just saying that pins tied high (1'b1) will be connected to VDD, and those tied low (1'b0) will be tied to VSS. Your pwr/gnd names may be different, but the keywords TIEHI and TIELO do not change here.
    Hope that helps,
    - Kari
