  3. Question for rc synthesis
  • Subscribers 94
  • Views 16876
flyinmeteor
flyinmeteor over 16 years ago
Hi i have a big block to synthesize. Inside this big block, I have a small block that is already custom designed. How can i tell RC not to touch this small block?
  • Scrivner
    Scrivner over 16 years ago
    set_attribute preserve true [find / -subdesign <module name>]
  • flyinmeteor
     I got an error saying cannot preserve partially unmapped or empty design or subdesign... what does it mean?
     thanks.
  • Scrivner
     You might get this error if you do the set_attribute before elaboration.
     Another issue might be if it cannot find the module you specified. To test this try:
     on the rc command line to see if it finds the module that want to preserve.
  • Krushnal
    Krushnal over 7 years ago in reply to Scrivner
    Even then the same error is persisting, what else can be done to solve it.
