  3. eco route
  • Subscribers 94
  • Views 16413
eco route
spach
spach over 16 years ago
I am working on a fully routed DB, when i used ecoaddrepeater to add buffers on some nets and then globaldetailroute, the routing of other nets r changing and i am getting lot of verifygeomentry violations.
can any one tell me a method to route ecoaddrepeater nets with out disturbing other net routing
regards,
spach
  • Scrivner
    Scrivner over 16 years ago
    First make sure you remove filler cells before you run ecoAddRepeater. Then after running ecoAddRepeater, you need to add the fillers back in and run ecoRoute.
  • spach
    Data base is postRouteOpt and i have not added fillers till now
