  3. clock tree levels and gating
  • Subscribers 93
  • Views 18648
archive over 19 years ago
I have tried SOC62, and have noticed that as soon as I add clock gating in RC, the number of clock tree levels blows out, in my case from 6 levels to 22.
I have tried all sorts of options and commands in the clock spec file, but the levels don't change much.
The gating happens very close to the root, and one would think that it should add just a couple of extra levels not 15.
What's worse is that with gating the skews also become a lot worse.
Is this normal?
AA
Originally posted in cdnusers.org by aus_amx
    Hi AA,
    When you place the design, try using setPlaceMode -clkGateAware 1. Hopefully a better placement of your clock gating logic will lead to a better tree when you get to CTS.
    - Kari
    Originally posted in cdnusers.org by Kari
    Hi Kari,
    Yes I have used this option as well.
    I am using the -keepPorts and fences to keep the ports of a block intact.
    Could this be causing the problem?
    Regards
    AA
    Hi AA,
    In re-reading this thread, I realized you were talking about RC. I don't have much experience there. I was thinking in terms of FE. Hopefully there is an RC expert around that may be able to offer some advice.
    If the -keepPort switch you mention IS in FE, then try a run without it and compare the results.
    - Kari
    archive over 18 years ago
    I have this issue as well... I have since learned I needed to manually build the clock tree to avoid this issue. I agree - it is specific to gated clock trees where the gate is close to the root.
    Originally posted in cdnusers.org by mboudreaux
    Hi mboudreaux,
    Have you tried to leverage SoC-Encounter's Integrated Clock Gating Cell cloning capability ("ckCloneGate")? In scenarios where there are multiple levels of clock gating with different enable signals, "setPlaceMode -clkGateAware true" has limited effectiveness in my experience.
    Bob
    Originally posted in cdnusers.org by BobD
  • porcupine
    porcupine over 17 years ago
    Hi all,
    With regards to using discrete clk gating cells, is it sufficient to jus set the cllkgateaware to true in Ecnounter? Do i need to specify additional settings in the clock spec file?
    Any advice is greatly appreciated! thanks :)
