  3. insertRepeater with inverters
  • Subscribers 94
  • Views 15584
Nishant
Nishant over 16 years ago
I'm using encounter to do repeater stitching of long non timing critical nets using the command insertRepeater. We ideally would like encounter to use single inverter with given length rule like the one below
source --------------------|>---------------------------|>-----------------------sink
but it tries to use pair of inverters for each stage.
source --------------------|>|>--------------------------|>|>----------------------sink
Is there any way we can ask encounter not to do that?
Nishant
  • Kari
    Kari over 16 years ago
     You could try setEcoMode –spreadInverter true, then use ecoAddRepeater instead of insertRepeater.
