  3. How to make Encounter recognize path through IE pin of ...
  • Subscribers 95
  • Views 14941
How to make Encounter recognize path through IE pin of IO
JZ Huo
JZ Huo over 16 years ago
ETS reports the timing path from reg --> IO/IE --> IO/C --> reg .
The IE pin is the input enable pin of this IO, and C pin is the output pin
to core of this IO.
But this path is unconstrainted in Encounter. How to let Encounter recognize
this path just as ETS, then optimize this path.
  • Kari
    Kari over 16 years ago
     Are you using the same constraints in both tools? Do you have all the same settings in both tools?
  • JZ Huo
     hi all
    set_global  timing_disable_internal_inout_cell_paths false
    It seems working.
