  3. Short between IO filler blockage and IO pad pin
  • Subscribers 95
  • Views 16968
maxb
maxb over 16 years ago
In our design we have IO fillers with blockage for the IO ring power & ground stripes, and IO pads with pins for the same busses. When placing fillers between the IO cells, we see short violations between the pad pins and the filler blockages (see attached image). How can we fix or ignore these violations?
The LEF for the IO filler and pad looks like:
MACRO IOFILLER
    OBS
        LAYER M3 ;
        RECT  0.00 78.50 5.60 104.06 ;
MACRO IOPAD
    CLASS PAD ;
    SITE IO ;
    PIN VDD!
        DIRECTION INOUT ;
        USE POWER ;
        PORT
        LAYER M3 ;
        RECT  0.00 78.82 75.04 83.58 ;
Link to GUI image: http://i42.tinypic.com/33di5jc.gif
Thanks in advance,
/Max
  • mikhail
    mikhail over 16 years ago
    To avoid shorts you have at least 2 ways:
    1. If blockage represents actual wire in the filler (not pad ring) then shorts are valid and you need to resize pad pin in IO cell to meet spacing (maybe you need to consider width-depended spacing rules).
    2. If blockage comes from pad ring wires in the fille, then you need to define related pins in filler cell. This will close pad ring connections and violations will gone.
    Hope this helps.
    Best regards,
    Mikhail.
  • ErezBS
    ErezBS over 13 years ago
    I am facing the same issue right now.
    can you please elaborate what should i check?
    Thanks!
  • Kari
    Kari over 13 years ago
    it sounds like the LEFs were not designed properly. the fillers should be able to be placed next to the functional IOs without problems. Instead of blockages in the fillers, they should be the actual pwr/gnd pins. you may just have to ignore the violations.
