  3. Unplaced IO pins
  • Replies 8
  • Subscribers 92
  • Views 18835
Unplaced IO pins
Greatrebel
Greatrebel over 15 years ago
Hi All, When I used checkDesign command in Encounter, I found there were a lot of unplaced IO pins. The number of unplaced IO pins is equal to the number of ports in my top-level design. I am wondering how to fix those unplaced IO pins or just leave them alone if it is not a big issue for P&R. Thanks in advanced
  • Kari
    Kari over 15 years ago
     Are your IO pads placed yet? Once the IO pads are placed, I believe the pins should be right on top of the IO PAD pins.
  • Greatrebel
     Hi Kari,
    I have already placed IO pads. I have a IO assignment file and use the command of loadIoFile to load that file. It works fine. But after that, when I type checkDesign, I still got a number of unplaced pins. I am wondering do I need to write something in IO assignment file for placing pins of top module,
  • Kari
     Hmmm. It's been a while since I've done a top-level design. Are the number of unplaced pins equal to the number of signal IOs? If you go on through placement and route, do these pins get placed later or do they cause routing issues?
  • Greatrebel
     Those unplaced pins are still there after routing, but I did not get an error for routing. The number of unplaced pins is not equal to the number of signal IOs but the port number of top module, since some ports have more than one bit.Does these unplaced pins really need to be clean out?
  • Kari
     If Verify Geometry and Verify Connectivity are clean, and your signoff DRC/LVS are clean, then you're probably fine, but it would always bother me where these things are coming from. The only thing I can suggest is to look at the names of the unplaced pins, see if they make sense in your netlist, or if they should be placed on an IO pad. Maybe these are leftover in a floorplan after the netlist got changed? Are they actual physical shapes, or just logical pin markers? Do they connect to any nets?
  • Greatrebel
     hi  Kari,
    I checked the report from checkDesign. All those unplaced IO pins are the pins of top module in the netlist. They have been connected to IO instances directly in the netlist. In PnR view, I saw those pins are bonded with IO instances' pins like PAD. Each of the unplaced pins are just shown as a yellow triangle.
    thanks
  • Kari
     I think everything will be fine then. :-)
  • Greatrebel
    Hi Kari
     Thank you very much!
