  3. How to import layout from Virtosuo to Encounter
  • Subscribers 94
  • Views 18263
Greatrebel
Greatrebel over 16 years ago
Hi All,
We are designing a chip which includes a mixed signal macro. I have the GDS for the MS macro. I am wondering how I can import the layout of the MS macro into our design in Encounter. I load into the gds file during design import, but nothing happens.
Any help will be greatly appreciated.
Thanks in advance
  • Kari
    Kari over 16 years ago
     The normal flow is to represent your MS macro with a LEF (for the physical data) and a .lib (for the timing data).
    - Kari
  • Greatrebel
    Hi Kari,
    Since LEF does not contain all the information about layout, after integration of the MS macro into our chip, the GDSII generated from Encounter will not contain the full details of the MS macro. I am wondering how I can bring the full information of the layout for the MS macro into the design. Or do I need to send off both the GDS of the whole design from Encounter and the GDS fro the MS macro to the foundry, and let them bring the MS GDS to the design?
    Aslo can Vituoso generate LEF and lib files?
     Thanks a lot
  • Kari
     To include the gds of your macro in the gds output from Encounter, you'll need to use the -merge option of the streamOut command. If the gds from Encounter is what you're sending to the foundry, then you should already be using -merge to get the full layouts of your stdcells and everything else.
    Alternatively, some design flows have all of the stdcell and macro libraries in Virtuoso, and stream the Encounter gds (without the -merge option) into Virtuoso referencing those libraries. Then you stream out the entire design to send to the foundry, and it has all the layout info.
    So you could do either one of these. But a word of caution - make sure that the gds you send to the foundry is the gds that you ran your signoff DRC/LVS on.
    I know you can export LEF from Virtuoso - depending on the complexity of your macro, it may or may not be what you need to generate the LEF. There is an abstract creation tool. Generating .lib is out of my field, I'm afraid. You should post a question to the Custom IC Design forum about the easiest way to get a LEF and .lib of your macro from Virtuoso.
    - Kari
  • Greatrebel
     Hi Kari,
    Thank you very much for your help. Actually we do not have the GDS files for std cells, I guess the foundry may merge the GDS of std and memory block into our design. Anyway, thanks a lot!
  • Kari
     You're welcome!
    I guess the foundry is running signoff DRC/LVS too, then. So if you just use -merge to include your MS macro, you should be good to go!
