  3. CTS for "scan en" and "reset" tree
  • Subscribers 95
  • Views 2270
Yemelya
Yemelya over 16 years ago
Could be CTS used to build tree not for clock, but for other signals with huge fanout, like scan enable or reset?
Is there a way to build tree for ONLY defined pins, without excluding all other pins which could be reached by CTS and interpreted as leaf points?
Thank you,
-Boris
  • mohanch
    mohanch over 16 years ago
    Yes CTS can be used for Building CTS for High fanout nets , Only things to be taken care is to use NoGating rising option in CTS spec file , and resetting the properties on   nets /instances .
  • Yemelya
    Thank You very much for your answer. If I understand you correctly, to set “NoGating YES”, and what do you mean by “resetting the properties on nets/instances”?
    Again, thank you.
    -Boris
  • Kari
    Kari over 16 years ago
     You can also use the bufferTreeSynthesis command.
  • Yemelya
    Thank you!
