  3. deciding insertion delay and clock skew.
  • Subscribers 95
  • Views 32534
gops
gops over 16 years ago
Usually in a clock tree file we need to provide the values of insertion delay and skew values.I have read , that its usually advisable to give 10% of clock period for minimum skew value if the chip is not much big in size and we can go below to 5% as chip size increases.Anyway the skew value is dependent on the technology also.If I make the skew value to a low value it will make my design consume high power, because of the clock  buffers needed to attain the skew value.So someone please throw some ideas how the skew value and insertion delay values can be chosen for a design.
I know the defenitions of both and also I know the skew value can't be more than the clock period.So please give me a clear answer from your experience, How I can decide a safe skew value for the clock which will meet the timing with minimum power consumption.
  • Kari
    Kari over 16 years ago
     This is going to be very design-dependent, so I think the best thing is to do several experiments until you find something you're happy with. For insertion delay, you may also need to make sure it's not bigger than the clock period.  Also, keep in mind that global skew isn't necessarily a target in itself - it's the local skew that matters. You may be able to still make timing with a bigger global skew (which should reduce the insertion delay/buffers). Sorry if this isn't much help - maybe some other users will chime in with some advice!
  • jagadishbvn
    jagadishbvn over 9 years ago
    Latency depends on the no of flops w.r.t that clock domain and pre-cts logic depths . If you pre-cts logic depth is high (more cts logic in the clock paths because of more controller logic added such as MUX , AOI ) then obviously your latency will be high .Assuming there is less logical cells from the cts root to the flops , the latency depends on the no of flops and the type of floor plan i.e your clock root pin placement and so on.There is no hard and fast rule , however the best possible way is to see how much latency you see when you do only drv fixing on clock paths in  cts .This option is available with the ccopt where its does only drv fixing and not skew. With this you can see the max latency seen from the clock root , if this latency is acceptable  and is required for the drv fixing assuming the placement of the flops is  appropriate  then it is  feasible to set  this as the max latency for your design . Coming the skew (global)  , you can blindly set it to 10% of clock period for initial analysis  but  is   technology dependent (foundry , PVT , ocv etc) and design dependent  ( ex processor and high speed data paths need very less skew to meet timing) where you cant compromise over the  skew .
