  3. How to Match Routing wire length?
  • Subscribers 94
  • Views 15279
Sundarsan
Sundarsan over 16 years ago
I have a 8Bit Data path, each path has equal number of buffers.
The buffers are placed at equal distance, now when i route the signals, all the signals should have equal wire length.
The Signal in the same path and the signals in the other 8bit paths should have equal wire length after routing.
How to achive this using Nano route?  Is there any special switch or setting to achieve this wire length matching?
Thanks in Advance,
Sundar
  • Kari
    Kari over 16 years ago
     Try routing these nets first. You can select the nets, run nanoRoute on selected nets only, then route the rest of the design.
