  3. Scan Reorder issue
  • Subscribers 93
  • Views 18047
Scan Reorder issue
Vishnu Chada
Vishnu Chada over 15 years ago
We have a scan connection as follows :
               FF1(from Q,SDFF)   -----------BUF ---------------FF2 (to D , DFF)
        ________(to other logic)
Scan def :
+ORDERED
        FF1 ( IN SI ) ( OUT Q )
        FF2  ( IN D ) ( OUT Q )
+FLOATING
When i do scan reordering the tool mess with the functional path which is shown in above representation.Connects that entire logic to other flop, which is caught in lec.It does not honor the ORDERED section properly.Is there any known issue where encounter has problem handling Regular Flop (with D input as part of the scan chain) in the ORDERED section instead of a ScanFlop ?
Tried using 7.1 and 8.1USR3.
Appreciate your help.
Vishnu
  • Vishnu Chada
    I was able to bypass the above mentioned issue by adding the buffer to the ordered list.But am still facing issue when the scan chain ends it D pin of the flop.
    + STOP <instance> D
     Using 8.1 USR3. I think encounter inherently has problem handling scan chains where there is  D pin in the chain instead of SI.
     Would like to know from the user community or cadence personnel if this is true from there previous experiences.
     Appreciate your time.
    Vishnu
  • maxb
    maxb over 15 years ago
    I had similar issues with EDI 9.12. Some flip-flops with scan input D instead of SI was marked as mismatch by LEC. During scan reordering with EDI warnings were issued about removing inverters in the scan chain and then having to correct logic:
    Successfully traced scan chain "chain0_seg1_clk_rising" (1939 scan bits).
    *info: delete instance top/subdesign/g5048 (INV_X1M_A12TR) along scan chain!
    **WARN: (ENCSC-1152):    In DEF scan chain "chain0_seg1_clk_rising", " g5048 ( IN A ) ( OUT Y ) ( BITS 1 ) " is skipped because the instance can not be found.
    **WARN: (ENCSC-1135):    In scan chain "chain0_seg1_clk_rising" DEF ordered section, buffers or logics following scan instance "top/subdesign/state_reg[2]" are corrected to match the netlist.
    after changing setScanReorderMode -skipMode from "skipTwoPinCell" to "skipNone" the warnings went away and the equivalency check was passing. I did not analyze exactly what went wrong in the first place though.
  • Vishnu Chada
    Thanks Maxb.Looks like this is an issue with placeDesign -inPlaceOpt.If i break the flow into
    placeDesign
    scanReorder
    OptDesign -preCts
    placeDesign -incremental
    optDesign -preCTS -incr
     scanReorder
    lec was clean.
     --Vishnu
