  3. set_clock_group behavior - SOC81USR3
  • Subscribers 94
  • Views 2487
Vishnu Chada
Vishnu Chada over 16 years ago
PLL --(CLK)--------------------------DIVIDER ---(gen_CLK1)---------------------------FLOP_GROUP1
                       |______DIVIDER ---(gen_CLK2)----------------------------FLOPS_GROUP2
I have two generated clocks from master clock CLK as pictured above.
When i define  CLK and gen_CLK2  as asynchronous clock groups i intend not to see timing paths between FLOP_GROUP1 and FLOP_GROUP2. When i load this constraint in encounter i see otherwise.
set_clock_groups -name group1 -asynchronous  -group  [get_clocks {CLK}] -group  [get_clocks {gen_CLK2}]
 I see a timing path between these flop groups clocked by generated clocks reported by encounter.
Is it not implicit that gen_CLK1 and gen_CLK2 are also asynchronous clock groups ?
Is there a switch i should use to see this behaviour with CTE ?
Appreciate your time.
Vishnu
  • Kari
    Kari over 16 years ago
     The documentation for set_clock_groups states that clock groupings on a master clock are NOT applied to generated child clocks.
  • Vishnu Chada
    Thanks for the response kari. Looks like i just need to add the generated clock to the same group as the master clock to see this behaviour. Regards, Vishnu
