  3. high reg2out
  • Subscribers 93
  • Views 18434
high reg2out
archive over 18 years ago
Dear all
I am working on timing ananlysis for  the first  time. after cts when i check for the setup timings i get the following values.
|     Setup mode     |   all   | reg2reg | in2reg  | reg2out | in2out  | clkgate |
|           WNS (ns):| -4.082  |  0.000  | -0.615  | -4.082  |   N/A   | -0.559  |
|           TNS (ns):| -1135.6 |  0.000  |-121.790 |-997.079 |   N/A   | -16.757 |
|    Violating Paths:|  1107   |    0    |   552   |   468   |   N/A   |   87    |
|          All Paths:|  42404  |  28604  |  16352  |   469   |   N/A   |  1685   |
I see that the slack for reg2out is high . can some one please tell me how can I reduce. please provilde me some material to read inorder to solve this
Thank u in advance
Suresh
Originally posted in cdnusers.org by suresh235
    Hi Suresh,
    Some additional questions: what is the step ? preCTS, potsCTS, postRoute ?
    Generally a big violation as your one is a timing constraint problem. You need to check the clocks (the one on the flop and the one on the out). You can also check the output_delay. Very often a big violation is a "false" violation. You can analyse this violation with the file generated by timeDesign (* _reg2out.tarpt).
    Regards ... Luc ...
    Originally posted in cdnusers.org by Black Lutin
    hello Lutin .
    Thank you for ur reply. the results i had shown above are post CTS values. looks ur right in mentioning abt the timing constriants. I am digging in with the sdc file . I did not get wat u meant by false violation, can u please explain me in detail or can u suggest me some material to read.
    I am also tring to understadn the file reg2out.tarpt.
    Thank your for ur help
    Suresh
    i am attaching a part of the report for reg2out.tar . i can see that for one cell that slew is too large .. any suggestion abt this ?
    | Cell | Slew | Delay | Arrival | Required |
    | | Time | Time |
    | | 0.300 | | 1.000 | -5.609 |
    | CKLNQD8 | 0.300 | 0.000 | 1.000 | -5.609 |
    | SDFCNXD | 0.032 | 0.220 | 1.220 | -5.389 |
    |CKND2 | 0.031 | 0.031 | 1.251 | -5.358 |
    | CKND2D | 0.044 | 0.038 | 1.289 | -5.320 |
    | NR2XD | 0.086 | 0.074 | 1.363 | -5.246 |
    | CKND2B | 0.029 | 0.042 | 1.405 | -5.204 |
    || TPND3D | 0.069 | 0.045 | 1.450 | -5.159 |
    | INVD16B | 0.026 | 0.034 | 1.485 | -5.125 |
    | INVD18B | 5.686 | 3.020 | 4.505 | -2.105 |
    | | 8.886 | 3.793 | 8.297 | 1.688 |
    Which encounter version are you using. I have some problem reading the format.
    Which command did you use for the TA report ? Normally it's timeDesign.
    "false" violations: suppose you hae a clock with a 10 ns period, and a people put 11 ns as an output_delay for a port clocked by this clock. The people make a mistake because it is impossible to achieve the timing.
    This is a "false" violation but a real error in the SDC timing constraints files.
    Regards ... Luc ...
    Hello Black Lutun ..
    the problem is solved, it was soem thing todo with sdc ..
    thanks again
    Suresh
