  3. How to report list of flops whose clock port is driven by...
  • Replies 8
  • Subscribers 92
  • Views 20215
How to report list of flops whose clock port is driven by test clock in test mode
diablo
diablo over 15 years ago
 Hi all,
  I have functional and test analysis views. The Test clock is muxed with functional clock whose selector is TEST_EN net.
  In my functional SDC, I have "set_case_analysis 0 TEST_EN" and in test SDC, I have "set_case_analysis 1 TEST_EN". I want to verify  whether in test analysis view, the Test clock is seen by all the flops.
  How to report the list of flops whose clock port is driven by test clock in test analysis view.
 Thanks for your time.
  • wally1
    wally1 over 15 years ago
     Try running "check_timing -verbose -view viewName". It will include a check to report clock pins which do not have a clock signal driving them.
     - Brian
  • diablo
    Hi Brian,
    Thanks for the reply.
    check_timing only reports whether clock pins are driven by a clock signal or not. Is there a way to report which clock is being used?
  • BobD
    BobD over 15 years ago
    What an awesome question this is - thanks for posting it.
    Brian's note about the -view option on check_timing is applicable to get_property as well, which you could use to check which clocks are associated with each clock pin per view.  I created a tiny circuit to test this, with clka and clkb being muxed differently in view "a" and view "b".  You can query the clocks like this:
    encounter 11> get_property -view a [get_pins i1/CK] clocks
    clka
    0x14
    encounter 12> get_property -view b [get_pins i1/CK] clocks
    clkb
    0x16
    To loop through all of the registers in the design and check you could do something like this:
    foreach_in_collection register [all_registers] {
      foreach_in_collection pin [filter_collection [get_pins [get_property $register hierarchical_name]/*] {is_clock == true}] {
        set clk [get_property [get_property -view b $pin clocks] hierarchical_name]
        if {$clk == "clkb"} {
          Puts "Pin: [get_property $pin hierarchical_name] in view \"b\" is driven by \"clkb\""
    Pin: i1/CK in view "b" is driven by "clkb"
    Pin: i2/CK in view "b" is driven by "clkb"
    Hope this helps!
    -Bob
  • diablo
    Hi Bob,
    I tried your solution and I have few questions on it.
    encounter 6> get_property -view func_worst [get_pins pc0/vreg_ovp_reg_0/CKN] clocks
    0x11692
    encounter 7> get_property -view test_worst [get_pins pc0/vreg_ovp_reg_0/CKN] clocks
    0x11694
    I did not get clock name as in your case.
    I tried the looping through the registers using your foreach loop and replacing correponding views and clock name.  For hierarchical_name i am assuming, i have to replace it with any instance name. This is what i had, but could not get it to run correctly.
      foreach_in_collection pin [filter_collection [get_pins [get_property $register pc0]/*] {is_clock == true}] {
        set clk [get_property [get_property -view func_worst $pin clocks] pc0]
        if {$clk == "CLK5"} {
          Puts "Pin: [get_property $pin pc0] in view \"func_worst\" is driven by \"CLK5\""
    When you have set clk[get_property...], the inner get_property gets the pins but what about the outer get_property? which property is it trying to fetch?
  • BobD
    Hmm - that's strange that it appears to be returning a collection, but the name of the clock isn't echoed.
    "get_proeprty [get_pins xxx] clocks" should get a collection of clocks.  To query the name of those clocks we need to:
    get_property [get_property -view func_worst [get_pins pc0/vreg_ovp_reg_0/CKN] clocks] hierarchical_name
    -or- if there are multiple clocks you could iterate through each like this:
    foreach_in_collection clk [get_property -view func_worst [get_pins pc0/vreg_ovp_reg_0/CKN] clocks] {puts "[get_property $clk hierarchical_name]"}
    "hierarchical_name" is an attribute off clocks and other objects alike so you shouldn't have to swap out hierarchical_name for instance_name.  The outer get_property returns the name, the inner get_property returns a collection.
    Let us know how these suggests enlighten things and we can go from there.
  • diablo
    Hi Bob,
    I am using  Encounter v09.12-s159_1.
    Thanks for the hierarchical_name explanation.
    Since  the clk name is not echoed, I am assuming this command will not work on my side. For sanity check, I ran
    encounter 2> get_property [get_property -view func_worst [get_pins pc0/vreg_ovp_reg_0/CKN] clocks] hierarchical_name
    **ERROR: (TCLCMD-917):  Cannot find 'modules, library, library cell, library pins, ports, instances, pins, clocks, nets, paths, points or arcs collection' that match ''
    Any suggestions?
    Thanks again.
  • BobD
    I altered my testcase such that no clock gets to the pin in the b view and I see what you're seeing:
    encounter 17> get_property -view a [get_pins i1/CK] clocks
    clka
    0x24
    encounter 18> get_property -view b [get_pins i1/CK] clocks
    0x26
    A modification to the script could catch the cases where the clock pin doesn't receive a clock:
        set clocks [get_property -view b $pin clocks]
        if {[sizeof_collection $clocks > 0]} {
          set clk [get_property -view b $clocks clk]
        } else {
          Puts "Pin: [get_property $pin hierarchical_name] in view \"b\" is not driven by a clock"
    Pin: i1/CK in view "b" is not driven by a clock
    Pin: i2/CK in view "b" is not driven by a clock
    Not sure that's going to pinpoint why the pins aren't receiving a clock.  You might want to check the report_case_analysis command for some insight into what's going on relateive to those constraints.
    -Bob
  • diablo
     Hi Bob,
    Thank you much for your scripts. This is exactly what i was looking for.
    However i thing you meant  "set clk [get_property -view b $clocks hierarchical_name]" instead of "set clk [get_property -view b $clocks clk]". I had to modify that to get it working.
    You are right about clock not getting to the pin for the missing clk names. I tried different register and i got the clk name back.
    Its working for me now ;-).
    Have a good day.
