  3. Library Characterization_ Simulation setup file
  • Subscribers 92
  • Views 506
affaq
affaq over 15 years ago
I am characterizing 90nm custom cells using encounter library characterizer. When creating simulation setup file, I have some questions about the parameter values.
*Does the default values mention in the ELC documentation works for 90nm process or they are independent of the process technology.
*What values to select for slew rate and load capacitance
*How to make room of calculating cell delay while characterizing the cells.
I am attaching simulation setup filefor consideration.
Thanks in advance
  • simulation2.txt
