  3. Danglling wires after LVS
  • Subscribers 93
  • Views 14288
ssuhas
ssuhas over 15 years ago
For my block level design I am getting danglling wires after doing verify connectivity.
I am getting these errors at the end of all standard cell rails.
What is the reason for the error and how do we debug it?
  • mikhail
    mikhail over 15 years ago
    What do you see on these markers?
    Is it opens? It can be caused by missing wires between rings/stripes and std cells rails.
    Please attach a screenshot for one of violations. It will help to debug it.
  • diablo
    diablo over 15 years ago
    do you have end cap cells at the end of core rows ?
  • ssuhas
    No I dont have any end cap cells at the end of core rows.....
  • diablo
    I would suggest adding end cap cells at the end of core rows using
     addEndCap
    [-help]
    -preCap cellName
    -postCap cellName
    [-prefix prefixName]
    [-coreBoundaryOnly]
    [-flipY]
    [-powerDomain powerDomainName]
    [-area x1 y1 x2 y2]
    End-cap cells are preplaced physical-only cells that are required to meet certain design rules.
    They are placed at the ends of the site rows.
    See if it fix your issue.
  • Kari
    Kari over 14 years ago
     For a block-level, you can probably ignore these. verConn is just telling you that these rails do not terminate at stripes, and depending on your design, that could be fine. (at the top-level, the rails will continue and end up terminating at stripes or a ring).
