  3. importing P/G pins into Encounter with .def file
  • Subscribers 94
  • Views 4126
archive over 18 years ago
Dear all,
I have been trying to get the pins (VDD and VSS) in the extracted .def file from cadence into Encounter. however, when i do the defIn cmd, it keeps giving me this error:
Pin "VSS" is not created because it's not in the netlist and also not a P/G pin.
>> I know it's not declared in the Verilog netlist since it is power/ground pin. Why does Encounter not recognize it as a P/G pin. even in my .conf file, i have this:
set rda_input(ui_pwrnet) {VDD}
set rda_input(ui_gndnet) {VSS}
so if anyone has experience the same, please let me know. thank you very much.
regards,
chhay
Originally posted in cdnusers.org by kongtep2
    HI,
    Just check in you're def file for "SPECIALNETS" sections for VDD and VSS pins . if you are missing them then use "defOut -floorplan" switch to get them in def file . and you get them even from .fp file (loadFPlan) with PGPin , PinBox having such information. hope it will solve your issue.
    Ex. : In PINS section
    - vdd + NET vdd + SPECIAL + DIRECTION INOUT + USE POWER
    + LAYER M4 ( -1440 0 ) ( 1440 280 )
    + FIXED ( 1092580 1191680 ) S ;
    You can also check in .fp ( floorplan) file for the fallowing syntax to existing of POWER and GROUND definition .
    PhysicalNet: vdd -pwr
    PhysicalNet: vss -gnd
    And for PGPins :
    PGPin: vss vss inout gnd fixed 671.8100 1708.8400 N 7 1
    PinBox: 669.2000 1703.6200 674.4200 1708.8400 -lyr 7
    Originally posted in cdnusers.org by mohanch007
    mohanch007,
    thank you very much. you saved me! I haven't been trying to figure this out for a long time. it works when i specify the special net/pin in the .def file from cadence.
    I have another question regarding power planning tho. so i created a rectilinear contour for the core with the placement blockage using the partition cut. so when i addRing around the contour of the block, it says:
    selected placement blockage (x1, y1, x2, y2) will be considered by addRing command as placement objects.
    another thing is that the Encounter won't let me addRing using the type: core ring(s) contouring. it says the check design boundary or specify valid offsets.
    please help.
    thank you soooo much for your help!
  • RubenReyes
    RubenReyes over 9 years ago
    How do you use the following syntax in the DEF in the SPECIALNETS section as a pin.
    What does the syntax mean?
    + LAYER m0 WIDTH 22 SPACING 18
