  3. no new cells at top level
  • Subscribers 93
  • Views 15804
archive over 18 years ago
I'd like to add no new cells(buffers, inverters...) at top level during timing optimization phase in Encounter. In synopsys flow, I have set compile_no_new_cells_at_top_level as true. Is there any options or variables to do like the above? Thanks in advance.
Originally posted in cdnusers.org by basian2
    I failed when trying to find something like this some time ago. In PKS the variable opt_no_new_instances_at_top_level controls such behavior, but it does not work for First Encounter.
    Cristiano.
    Originally posted in cdnusers.org by clsantos
    Try -addPortAsNeeded switch of SetOptMode.
    It would not add ports that disturbs the hierarchy of the design.
    Originally posted in cdnusers.org by Devi
    Hi, I already tried -addPortAsNeeded(-neverAddPort) switch of setOptMode. As you mentioned, it didn't add ports/pins that disturbs hierarchical boundaries of the design. But, a lot of buffer/inverter pairs were still added into the top level hierarchy. I'm looking for another variables/options to prvevent Encounter from add new buffers(inverters) into top level hierarchy during optimization phase. Thanks in advance.
