  3. how could FE extract coupled C when doing timeDesign?
  • Subscribers 93
  • Views 15525
archive over 18 years ago
Hi,All based a routed design,when i do timeDesign,FE extracts RC,below is a part of the log: Nr. Extracted Resistors : 1721541 Nr. Extracted Ground Cap. : 1821440 Nr. Extracted Coupling Cap. : 0 actually,it's not what I expected,i wanna coupling cap be expected. i try to setExtractRCMode -coupled true,it does not work,and after doing timeDesign,the -coupled is false when getExtractRCMode.. so ,could anyone help,thanks in advance.
Originally posted in cdnusers.org by yhu
    To extract coupled cap. during time deisgn, You need to enable -si option of timeDesign.
    Originally posted in cdnusers.org by Devi
    To extract coupled cap. during time design, You need to enable -si option of timeDesign.
    Devi,
    Thanks a lot.
