  3. LeafPin usage in CTS
  • Subscribers 93
  • Views 16442
MaK78
MaK78 over 15 years ago
I have a hierarchical circuit like one shown in attached picture. I would like to stop CTS at "in1" input of module "stage1".
So I added LeafPin definition in my clock specification file.
I tried both:
"LeafPin
+stage1/in1 falling"
and
"LeafPin
+stage1/U1/A falling"
but I received this warning for both:
**WARN: (SOCCK-665): The LeafPin +stage1/in1 falling is an invalid name.
**WARN: (SOCCK-665): The LeafPin +stage1/U1/A falling is an invalid name.
Furthermore it detects clock gating hold violation at U2 in stage2 (attached picture) and adds some buffers in the input of U2 which I wanted to avoid.
I would appreciate if anybody can help me.
by the way, I am using SOC Encounter 8.1.
Thanks in advance.
  • wally1
    wally1 over 15 years ago
     Please try putting a space after the plus sign "+":
    LeafPin
    + stage1/U1/A
    otherwise it thinks the + is part of the instance name.
  • MaK78
    Thanks a lot wally1. It works on instance pin :)
    It seems LeafPin doesn't work on hierarchical pins like "+ stage1/in1".
    I have another issue. I have defined both stage1/U1/A and stage2/U2/A as LeafPin (even ExcludedPin) but  "Analyze timing" generates "clock gating hold violation" on pin stage2/U2/A (The other pin of U2 comes from a register) while it shouldn't consider it as a clock anymore.
    Thanks again
  • MaK78
    Does anybody know why network after LeafPin is still checked for clock timing violations (like clock gating hold violation in above example)?
    Thanks in advance.
