  3. NRDB-1005 warning
  • Subscribers 93
  • Views 14143
NRDB-1005 warning
mwhite
mwhite over 14 years ago
If "setOptMode -fixFanoutLoad" true is applied before post route optimization, this warning gets generated during post route optimization:
  #WARNING (NRDB-1005) Can not establish connection to PIN a at (10.220 15.540) on M1 for NET B2T. The NET is considered partially routed.
Is this something I should be concerned?  Will the tool fix any issue associated with this?  Is there a way to make sure that this is not causing an issue?
Thanks!
  • Kari
    Kari over 13 years ago
     Check those coords and see if there is something blocking the routing. If you don't see anything, run a verifyConnectivity after NanoRoute to make sure everything got routed properly.
  • deepu
    deepu over 13 years ago
    Hi All,
      I have the same warning when doing an optDesign -postRoute -hold.  But I have no errors/warnings for verifyConnectivty. Does that mean the warning can be ignored? Below is the log. Thank you!
    #Merging special wires...
    #WARNING (NRDB-1005) Can not establish connection to PIN Q at (364.700 622.025) on MET1 for NET FE_PHN26_RST_N. The NET is considered partially routed.
    #WARNING (NRDB-1005) Can not establish connection to PIN A at (356.300 622.050) on MET1 for NET RST_N. The NET is considered partially routed.
    #47 routed nets are extracted.
    #    2 (0.11%) extracted nets are partially routed.
    #1677 routed nets are imported.
    #16 routed nets are fixed|skipped|trivial (not extracted).
    #Total number of nets = 1740.
    #Number of eco nets is 2
  • wally1
    wally1 over 13 years ago
    Yes, you can ignore the warning if everything is connected properly. This solution provides some more insight into the message:
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=11712200
    Brian
