  3. ELC Simulation failed with status 512
  • Subscribers 93
  • Views 15061
rangha
rangha over 14 years ago
 I am trying to create a standard cell library with transistor level model written in verilog A.
I am getting the following output
               Simulation Summary
   DESIGN    |   PROCESS   |   #ID    |   STAGE    |  STATUS   |    IPDB
INVX1          typical       D0000     SIMULATE     FAIL        all_cells_tfet
INVX1          typical       D0001     SIMULATE     FAIL        all_cells_tfet
When I checked the log file for error. I see " Simulation failed with status 512".
What does this error mean? Can anyone help me fix this issue?
 Rangha
  • eklikeroomys
    eklikeroomys over 14 years ago
     Is your simulation running time long enough?
  • Thodoros
    Thodoros over 13 years ago
    I have the same problem when I try to characterize an inverter based on umc 65nmll technology. I use different configuration, setup and command file and I always result with "Simulation failed with the status 512" .
    Can you please help me?
    Below are the command output, and besides  the elc configuration, command and setup files.
     Part of command output:
      stimulus generation  summary
    Name            #MOS    #DVEC   #RVEC
    INVX1           2       2       0
                            2       0
     Reading setup file : /home/simop/cadence/umc65ll_lib/ELC/setup.std
     -        INVX1 (CELL) -      typical - 2012-07-13 12:25:26 (2012-07-13 09:25:26 GMT)
    elc>   db_gate
          DESIGN : INVX1
    DESIGN ( INVX1 );
    //       PORT DEFINITION
            INPUT A ( A );
            OUTPUT Y ( Y );
            SUPPLY0 GND ( GND );
            SUPPLY1 VDD ( VDD );
    //       INSTANCES
            NOT ( Y, A );
    END_OF_DESIGN;
    elc>  db_spice -s spectre -keep_log -keep_wave
       DESIGN        PROCESS       #ID         STATUS     IPDB
    INVX1          typical       D0000         SIMULATE     ceid_vlsiLab_umc65ll_stdCells
    INVX1          typical       D0001         SIMULATE     ceid_vlsiLab_umc65ll_stdCells
    INVX1          typical       2          2            ceid_vlsiLab_umc65ll_stdCells
     2012-07-13 12:25:26 (2012-07-13 09:25:26 GMT) : Vectors Launched 1/2
     2012-07-13 12:25:26 (2012-07-13 09:25:26 GMT) : Vectors Launched 2/2
                   Simulation Summary
    INVX1          typical       D0000     SIMULATE     FAIL        ceid_vlsiLab_umc65ll_stdCells
    INVX1          typical       D0001     SIMULATE     FAIL        ceid_vlsiLab_umc65ll_stdCells
    elccfg:
    #Specify the environment variable settings.
    EC_SIM_USE_LSF=1;
    EC_SIM_LSF_CMD=" ";
    EC_SIM_LSF_PARALLEL=10;
    EC_SIM_TYPE="spectre";
    EC_SIM_NAME="spectre";
    EC_SPICE_SIMPLIFY=1;
    EC_CHAR="ECSM-TIMING ECSM-POWER";
    #Specify the characterization inputs.
    SUBCKT="ceid_allStdCells_ELC.scs";
    MODEL="ll_rvt.scs";
    DESIGNS="INVX1";
    SETUP="/home/simop/cadence/umc65ll_lib/ELC/setup.std";
    PROCESS="typical";
    Command file:
    db_open ceid_vlsiLab_umc65ll_stdCells
     db_prepare -f
     db_gate
    db_wave -d INVX1 -p typical -id D0000
     db_output -lib out.lib -process typical -state
     db_close
     exit
     Setup file:
     Process typical {
            voltage     = 1.2   ; // as voltage
    temp        = 25    ; /* as temperature */
    Vtn     = 0.208 ;
    Vtp     = 0.208 ;
    Process best {
            voltage     = 1.32   ; // as voltage
    temp        = 0    ; /* as temperature */
    Vtn     = 0.272  ;
    Vtp     = 0.272  ;
    Process worst {
            voltage     = 1.08   ; // as voltage
    temp        = 125    ; /* as temperature */
    Vtn = 0.192  ;
    Vtp = 0.192  ;
    Signal  std_cell {
    unit  = REL  ;          // relative value
    Vh    = 1.0  1.0 ;      // 100% rise/fall
    Vl    = 0.0  0.0 ;
    Vth   = 0.5  0.5 ;     // 50% rise/fall
    Vsh   = 0.8  0.8 ;
    Vsl   = 0.2  0.2 ;
    tsmax = 1.0n     ;     // maximum output slew rate
    Simulation std_cell {
    transient    = 1.0n 100n  10p  ;
    bisec        = 6.0n 6.0n 10ps ;  // binary search
    resistance   = 10MEG;
    Index   X1 {
    BSlew  = 0.0385N 0.5360N 2.0000N ;  // optional for binary search
    slew   = 0.0385N 0.0744N 0.1440N 0.2780N 0.5360N 1.0360N 2.0000N ;
    load   = 0.00082P 0.00330P 0.00842P 0.01848P 0.03861P 0.07870P 0.18975P ;
    Index   XL {
    load   = 0.00041P 0.00165P 0.00421P 0.00924P 0.01930P 0.03935P 0.09488P ;
    Index   X2 {
    load   = 0.00165P 0.00660P 0.01683P 0.03696P 0.07722P 0.15741P 0.37950P ;
    Index   X3 {
    load   = 0.00248P 0.00990P 0.02524P 0.05544P 0.11583P 0.23612P 0.56925P ;
    Index   X4 {
    load   = 0.00330P 0.01320P 0.03366P 0.07392P 0.15444P 0.31482P 0.75900P ;
    Index   X6 {
    load   = 0.00495P 0.01980P 0.05049P 0.11088P 0.23166P 0.47223P 1.13850P ;
    Index   X8 {
    load   = 0.00660P 0.02640P 0.06732P 0.14784P 0.30888P 0.62964P 1.51800P ;
    Index   X12 {
    load   = 0.00990P 0.03960P 0.10098P 0.22176P 0.46332P 0.94446P 2.27700P ;
    Index   X16 {
    load   = 0.01320P 0.05280P 0.13464P 0.29568P 0.61776P 1.25928P 3.03600P ;
    Index   X20 {
    load   = 0.01650P 0.06600P 0.16830P 0.36960P 0.77220P 1.57410P 3.79500P ;
    Index   CK_SLW {
    bslew   = 0.0385N 0.5360N 1.0360N ;
    Group   CK_SLW {
    PIN = *.CK ;
    Group   XL {
    CELL = *XL ;
    Group   X1 {
    CELL = *X1 ;
    Group   X2 {
    CELL = *X2 ;
    Group   X3 {
    CELL = *X3 ;
    Group   X4 {
    CELL = *X4 ;
    Group   X6 {
    CELL = *X6 ;
    Group   X8 {
    CELL = *X8 ;
    Group   X12 {
    CELL = *X12 ;
    Group   X16 {
    CELL = *X16 ;
    Group   X20 {
    CELL = *X20 ;
    Margin   m0 {
    setup   = 1.0 0.0 ;
    hold    = 1.0 0.0 ;
    release = 1.0 0.0 ;
    removal = 1.0 0.0 ;
    recovery = 1.0 0.0 ;
    width   = 1.0 0.0 ;
    delay   = 1.0 0.0 ;
    power   = 1.0 0.0 ;
    cap     = 1.0 0.0 ;
    Nominal  n0 {
    delay   = 0.5 0.5 ; // as rise fall
    power   = 0.5 0.5 ;
    cap     = 0.5 0.5 ;
    // Control Section
    set process (best,typical,worst) {
    simulation = std_cell ;
    index      = X1    ;
    signal     = std_cell  ;
    margin     = m0    ;
    nominal    = n0    ;
    set index  (best,typical,worst) {
            Group(XL)  = XL  ;
    //      Group(X1)  = X1  ;
            Group(X2)  = X2  ;
            Group(X3)  = X3  ;
            Group(X4)  = X4  ;
            Group(X6)  = X6  ;
            Group(X8)  = X8  ;
            Group(X12) = X12 ;
            Group(X16) = X16 ;
            Group(X20) = X20 ;
    Group(CK_SLW) = CK_SLW ;
    Thanks in advance,
    Thodoros
  • rangha
    rangha over 13 years ago
    Check the .lis file in the work dir.
    It will have detailed reason this error.
    In my case, it was due to the model files.
    Hope this helps.
    Rangharajan Venkatesan
    Research Assistant
    Integrated Systems Laboratory
    Purdue University
  • jsaenznoval
    jsaenznoval over 10 years ago
    Hi Thodoros,
    The bisection step must be larger than transient simulation step for convergence. Check it.
    Regards
