  3. get outline of an commlex polygon with holes in it ?
  • Subscribers 95
  • Views 17285
The Consultant
The Consultant over 14 years ago
is ther a way to get this outline( without the hole)
 at the mement i use
dbshape [dbshape $shapelist SIZE 1]  SIZE -1
to get ride of the holes, but i have to know the size of the holes to eleminate them.
regards
  • jgentry
    jgentry over 14 years ago
    Is there a max hole size that you can think of? If so, that should be adequate to remove the holes using your method. There's the issue of killing any 'indents' in your poly. Interesting problem.
  • The Consultant
     what you mean with 'indents' ?
  • jgentry
    Here's a sample polygon with "indents" and a hole: http://twitpic.com/7m6g0g If you do the following operation (assume 10 is hole size): dbShape -d -output rect $poly SIZE 10 SIZE -10 You end up with a square (outline is not preserved): http://twitpic.com/7m6gsk
  • jgentry
    Huh, my images disappeared. Try this: Poly: http://twitpic.com/7m6o9t Rect: http://twitpic.com/7m6oph
  • The Consultant
    if the hole is 10 x 10 than size up/down by 5 is enough .
    by th way what -d means ?
  • jgentry
    You are correct about the size operation (5 versus 10). However, the indent corner-case still occurs either way. The -d option forces dbShape into "DBU-coordinate" mode. I always specify it as a matter of habit so as to avoid any surprises.
