  3. How to update a tech LEF in an opened design in EDI 11
  • Subscribers 94
  • Views 16027
chadhale
chadhale over 14 years ago
I am developing LEF tech files.
I need to be able to make a tech LEF change and quickly see the effects in an already opened and routed design in Encounter.
In particular DRCs.
loadLefFile only updates antenna info.
I need to update everything without restarting the design.
Chad
  • chadhale
    Turns out you can not do this.
    http://support.cadence.com/wps/myportal/cos/COSHome/viewsolution/!ut/p/c5/dY1bDoIwFAXX4gruLWqtn9iIQg1EICr8kKJo0L4ivlcvLsA5n5OTgRL6GfloT_LWWiMV7KCkFfEWnIgRThMeMwwZjUW6mWMPbH8PWuEffIQCysnPex5hOF0E-QxDLsKITYYeCgobY6-6L-Www1GVndFFeTZ8vvefFbGsE5mLyboRQXI0Kiov4_txrJpCu7R26ctK7e61dl1Nk4NUvOO-_16pthhAvLS6AXcxn4D5gy-FOfoS/dl3/d3/L2dBISEvZ0FBIS9nQSEh/
    Excerpt copied from above link:
    Unfortunately, no. It's not possible to update a technology LEF on an active design. You don't have to end your session; you can clear the entire design and rerun init_design after changing the init_lef_file global (EDI11) or clear and run loadConfig/commitConfig (EDI10) but you cannot change tech lefs on the fly.
    loadLefFile can load new antenna data. It also is used "under the covers" by certain commands that pass LEF/DEF information to other engines and can be used to some extent as a LEF checker. But it will definitely not overwrite existing tech LEF data.
    cheers,
    chad
