  3. Missing power net
  • Subscribers 94
  • Views 17460
Missing power net
schnufff
schnufff over 14 years ago
 Hi all,
 I changed my flow from dc_shell to rc. In the past, when I imported my design to Encounter, there was the option to specify power and ground nets(import design->advanced->power). Now I import my RTL code and let rc synthesize it. But in contrast to dc, now 2 of my four power nets are missing. My IO-pads have pins vdd_core,vss_core,vdd_io,vss_io defined in the lef file. But only the global nets for  vdd_core and vss_core are created by rc. Therefore I am unable to connet the pins to the non-existent nets. I tried to instanciate the nets by hand (wire vdd_io;), but this doesn't work. Is there a way to create the two nets vdd_io,vss_io after the rc run, so that encounter can work with them?
The pin are defined like bleow in the lef file:
MACRO IO_Cell
 PIN vss_io
 END vss_io
PIN vdd_io
 DIRECTION INOUT ;
 USE POWER ;
 END vdd_io
PIN vss_core
  DIRECTION INOUT ;
  USE GROUND ;
  END vss_core
END IO_Cell
Regards
stefan
  • Kari
    Kari over 14 years ago
    Power and ground nets are not typically in the netlist. These are usually handled in EDI with the globalNetConnect statement. The LEF pwr/gnd pins should all be direction INOUT and USE POWER or USE GROUND as appropriate.
  • schnufff
     Thanks Kari,
    but how can I connect non-existing nets with "globalNetConnect? I can connect my the vdd,vss pins of my standard cells with vdd_core and vss_core, because the later already exist in the net list. But for the vdd_io,vss_io pins of the io_cells it is not possible, because the nets don't exist. Both net types (*_core,*_io) are specified exactly the same way in the lef file.Is there a way to mark existing nets as power/ground special nets?
     Regards
    Stefan
  • Kari
    physical-only nets, such as those created with globalNetConnect, do not need to exist already in the netlist. They get created when you specify them with globalNetConnect.
