  3. TIE-HI and TIE_LO cells
  • Replies 8
  • Subscribers 94
  • Views 19057
vedamrit
vedamrit over 13 years ago
Hi
Can we use VDD and VSS in place of TIE-HI and TIE-LO cells as they are logically equal .
Regards
Amrit
  • diablo
    diablo over 13 years ago
    No. VDD/VSS if tied directly to gate of NMOS/PMOS, noise in the power supply may turn on the gate. This effect is mitigated by using special cells like TIEHI and TIELO that prevent the MOS from inadvertently turning on with power/ground bounce.
  • tstark
    tstark over 13 years ago
    Don't some vendors allow direct VDD/VSS connections?
    I'm not a layout guy, so I'm not sure how this is handled electrically (diodes, caps, etc.) but I've seen it before. Maybe some vendors allow but risk the noise issue?
    tstark
  • vedamrit
    Whether this is appicable for 90nm and 130 nm also or we are using its for 65, 45 or 28nm only .
  • selvam27
    selvam27 over 13 years ago
    I tried this in 45nm and 130 nm ,direct connections of VDD/VSS instead of TIE-HI/TIE-LO is supported and it does't create any lvs issues
  • Amare
    Amare over 13 years ago
    We ever had this kind of direct connection in our 0.18um chips.
  • Ganga111AtFPS
    Ganga111AtFPS over 13 years ago
    Hi diablo,
    How to make a TIE-HI or TIE-LO cells to drive constant 1-logic or constant 0-logic electrically?
    To what terminals we will connect VDD/VSS nets ?
    Gangadhar
  • diablo
    TIE-HI and TIE-lo cells are already tied to constant 1-logic and costant 0-logic respectively.
    To connect gates that are driven to constant 1 or 0 to tie cells, in RTL compiler there is command
     'insert_tiehilo_cells -hi TIEHI_A7TULL -lo TIELO_A7TULL -all -maxfanout 20 -verbose'
    To have global net connectivity physically, in Encounter you will have to run
    globalNetConnect VSS     -type tielo -inst * -module {} -override -verbose
    globalNetConnect VDD     -type tiehi -inst * -module {} -override -verbose
  • Ganga111AtFPS
    Thank you..
