  3. dbcommands
  • Subscribers 94
  • Views 16221
dbcommands
ArvindBezawada
ArvindBezawada over 13 years ago
Hi how to give adress of timing library and other valuies using this command
 dbNetEvalDelayAndTran netPtr timeArcPtr rise_delay(ns) rise_trans(ns) fall_delay(ns) fall_trans(ns)
 RightNow for reporting slew value of a net using "reportNet -net net_name"..This is taking longer time ..if it is a post route database it is
going for full chip extraction and then it is reporting so can we use any dbget command as alternative.......
  • BobD
    BobD over 13 years ago
    I think the best way to query values like these are with the Advanced Timing TCL commands like these for example:
    encounter 1> get_pins DTMF_INST/TDSP_CORE_INST/i_10084/Y
    encounter 2> report_property [get_pins DTMF_INST/TDSP_CORE_INST/i_10084/Y]
    max_transition                      | 4.500
    slew_max_fall                       | 0.398
    slew_max_rise                       | 0.739
    slew_min_fall                       | 0.398
    slew_min_rise                       | 0.739
    encounter 10> get_property [get_pins DTMF_INST/TDSP_CORE_INST/i_10084/Y] slew_max_rise
    0.739
    A nice thing about get_property is that you can specify which MMMC view you want query:
    encounter 11> get_property [get_pins DTMF_INST/TDSP_CORE_INST/i_10084/Y] slew_max_rise -view setup_func
    0.739
    Think these will help meet your needs?
  • ArvindBezawada
    Hi BobD thanks for this...i tried this but report_property..if i use that again it is going to start full chip extraction and then it is reporting the values as u mentioned...as my design is at post route stage.....
     So is there any time saving ...in the sense any dbcommand available....to give the value directly with out going for extraction
     Thanks..
    Arvind
  • BobD
    Once the timing graph is built, you should be able to query the timing graph without re-extracting. Could you try doing a "timeDesign -postRoute" and then calling report/get_property?
  • chirag maniya
    chirag maniya over 13 years ago
    Looks like ...When you load a fresh databsase and then use report_property then it will extract for full design.
    So First use report_timing and then use 'report_property' command.
    If you already have done report_timing on design then it will not extract again.
  • ArvindBezawada
    common man...i know that i am fresh and my database is fresh...only thing i need is is there any alternate dbcommand...Thats what i want...chirageeeeey...
